2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Is a lap wiring harness comparable with a le5 engine
Old 01-14-2019 | 07:19 PM
Cobaltracecar's Avatar
I’m building a circle track Racecar it’s a 2009 Chevy cobalt and I’m about to send the wiring harness and computer in to get tuned and become a stand alone wiring harness but I’m planning on putting in a le5 2.4 and was wondering if I can put the le5 in using my wiring harness or if I should get a whole le5 wiring harness and have that tuned instead
Old 01-15-2019 | 07:36 AM
They are aimilar but not the same. Unless you want to dig into diagrams and modify it, its not worth it.
Old 01-15-2019 | 11:16 AM
but I can put a 2.4 block 2.4 intake and 2.4 throttle body?
Old 01-15-2019 | 11:27 AM
exninja's Avatar
If you're sending the harness somewhere to be modified it's probably not worth it to send them the 2.2 harness (the $50-$100 you'll spend on the harness is not much compared to how much you're likely about to spend). Just find an LE5 harness to send them and make sure your harness and computer match.
The throttle body may or may not be compatible. Not sure on the coils and injectors.
I should have read your question more closely, my mistake. The wiring CAN be different bewteen the two, but if youre putting the LE5 in an 09 car, it should be a direct swap.
Old 01-15-2019 | 11:48 AM
okat sorry so just so I’m clear you’re saying I can just drop in a newer le5 engine using my old wiring harness?
Old 01-15-2019 | 12:14 PM
Send a message to Nhanson, hes done it before.
Pokerking1993
02-18-2014 09:07 PM
Itsjustacivic
05-23-2007 07:55 PM
Quick Reply: Is a lap wiring harness comparable with a le5 engine
