2.2 wire harness to 2.4
Old 10-15-2015 | 04:28 PM
boost50psi's Avatar
Hey guys just seeing if someone could help me out I have someone that wants to buy my 2.4 motor and put it in there 2.2 to turn it into a track car does anyone know if the wire harnesses are the same ? They are the exact same year why will he need the PCM and ECU? Any help on this would be great thanks guys
Old 10-15-2015 | 11:23 PM
Its a good amount of work to get it all running that way unless you swap the whole harness
Engine harness that is
Old 10-16-2015 | 12:03 AM
Twoozofjuice's Avatar
Pretty sure nick Hanson swapped a 2.4 into his 2.2 without much work..
Old 10-16-2015 | 12:07 AM
EFIHARNESS's Avatar
what year are we talking about. Some of the same year 2.2, and 2.4's did not have vvt,one cam sensor, Etc.
you would need to reflash the ecu. Steve
Old 10-16-2015 | 12:48 AM
It depends on the year, not as easy on an 07
Old 10-16-2015 | 07:35 AM
boost50psi's Avatar
They are both 2006 vvt so should I just give him both engine bay harnesses and inside the cab?
Old 10-16-2015 | 08:50 AM
boost50psi's Avatar
Ya his motor is not a vvt but he shouldn't need a reflash if he is using my ecu and pcm right?
Old 10-16-2015 | 08:53 AM
Using your harness and ecu is the best way. But will require you to disable the antitheft system i believe
Old 10-16-2015 | 09:13 AM
boost50psi's Avatar
Well he's going to have to figure that one out .
Old 10-16-2015 | 10:54 AM
You can do it with hptuners. Its the only way mine would work when i swapped it
Old 10-19-2015 | 06:30 AM
boost50psi's Avatar
Now this is my next problem for him I guess last year sometime I must have sold the BCM will he be able to run his and just run my PCM?
Old 10-19-2015 | 09:51 AM
As long as you disable antitheft it should work, assuming you repin all the differences in the connecter that connects the two harnesses
Old 10-21-2015 | 01:54 AM
Yep his was 09 so had vvt already
riceburner
10-28-2015 10:13 AM
rdo1708
10-12-2015 11:09 PM
Ecotecftw
Tuning
13
10-11-2015 09:33 PM
Jon Jessie Cremeans
10-11-2015 02:33 PM
Barkleyj605
10-08-2015 10:35 PM
Quick Reply: 2.2 wire harness to 2.4
