2.4 LE5 Fuel Pump Capabilities
Old 04-04-2008 | 09:37 AM
celicacobalt's Avatar
Exclamation 2.4 LE5 Fuel Pump Capabilities
Does anyone here have info on what the 2.4's fuel pump can deliver? Looking to get 300whp with the stocker if possible if it's not possible, does anyone know of a direct replacement for our cars?
Old 04-04-2008 | 04:57 PM
bigworm's Avatar
log the fuel pump and find its duty cycle. it shouldn't be an issue for 300whp with a turbo..
Old 04-04-2008 | 05:50 PM
cool thats what I'm hoping. Now my next limit is how far I can push 42# injectors.
Old 04-04-2008 | 06:53 PM
pjk91's Avatar
probably not much further. id guess around 250whp is the limit for the 42's. as for the pump, i think they run out around 350whp ish on thelsj's so if we have the same pump...give or take somewhere around there.
Old 04-05-2008 | 07:39 AM
bigworm's Avatar
250whp for 42's is pushing it.... defiantly need 60's to 300, my guess is they will be at there limit here and you'll need bigger for 300+
Old 04-05-2008 | 09:35 PM
does anyone know what size injectors the solstic hahn stage 2 turbo kit comes with? whatever the stage 2 on the solstice is they use the same injectors for the 300whp stage 3 kit.
Old 04-08-2008 | 07:52 AM
this is all GM could tell me on the fuel pumps limits but I have since heard from a reliable source that the stocker should be able to support the 300whp goal I have.
Thank you for contacting the Chevrolet Customer Assistance Center. We
appreciate you taking the time to write and inquire about
specifications of the 2006 Chevrolet Cobalt SS 2.4 LE5, particularly with regard to
its fuel pump.
We do apologize but we actually don’t have any specific
specifications for the fuel pump. However, as far as my research goes, I was able
to gather some pieces of information pertaining to the 2006 Chevrolet
Cobalt SS LE5 with Ecotec 2.4L VVT engine. These pieces of information
are as follows:
Type: 2.4L DOHC VVT I-4
Displacement (cu in/cc): 145 / 2384
Bore & stroke (in/mm): 3.46 x 3.85 / 88 x 98
Block material: cast aluminum
Cylinder head material: cast aluminum
Valvetrain: overhead camshafts, 4 valves per cylinder; variable valve
timing
Ignition system: electronic direct, coil-on-plug
Fuel delivery: sequential multi-port fuel injection with high-flow
injectors and electronic throttle control
Compression ratio: 10.4:1
Horsepower (hp/kw@rpm): 171 / 128 @ 6200*
Torque (lb-ft/Nm@rpm): 163 / 221 @ 5000*
Recommended fuel: premium recommended but not required
Max engine speed(rpm): 6750
Exhaust system: stainless steel with aluminized coating on the
muffler and tailpipe
Emissions controls: close-coupled catalytic converters; High
Resolution 58X ignition system; return less fuel delivery system; fast-response
O 2 sensor
Fuel tank (gal / L): 13.2 / 49
Engine oil (qt / L): 2.4L: 5 / 4.7
Cooling system (qt / L): 2.4L: 7.4 / 7
Old 04-08-2008 | 12:52 PM
REDFOCZ's Avatar
That did not tell us anything we did not know already
Man you think GM would know what the parts are rated for
05-28-2022 03:47 AM
no_ss
10-18-2015 11:58 PM
DocSvensk
09-27-2015 02:24 PM
Adiaz1ss
09-26-2015 11:51 PM
roth
09-26-2015 12:16 PM
Quick Reply: 2.4 LE5 Fuel Pump Capabilities
