2.4 N/A round track engine
#51
#59
#61
#62
Nice power, pretty much what I would expect. 3kpa seems like a lot, are they forced to run a stock airbox? I'd imagine the 2.4L intake manifold isn't that restrictive, the runners are pretty good size from what I remember.
#63
The 2.4 intake manifold is actually quite small once you start modifying the already restrictive head.
#64
I tried to but they said no
it is on a gm cold air intake im trying to get them to put a lsj tb on it or a ls4
#65
I found the LSJ TB to be utterly useless, car felt flat below 3000rpm and didnt feel any gains above that and didnt see any gains in the MAF table either. My belief is that because the ZZP adapter plate still reduces the opening to the size of the LE5 throttle body the potential gains are negated automatically, and the wider opening before the throttle body only reduces incoming air velocity. You might get better results with a ported throttle body.
I happened across this a few weeks ago and im likely going to do a similar modification on mine only using a precision lathe rather then a dremel.
https://www.cobaltss.net/forums/2-0l...esults-149064/
Not sure why the dyno sheet wont show anymore but you can view it in google images if you type "LSJ ported throttle body dyno".
