2.4 Pirelli Tire Pressure
Hey guys, im stuck at work w/o my manual and need to know what the average PSI is for our tires.. im about to drive 6 hours straight from work and need to know if my tires are ok. Thanks!
Actually i checked the door jam and it said nothing about the tire pressure, nor could i find it on the side fo the tire.. but thanks for the heads up on the 32psi... appreciate it!
for the people who read the side of the tire, you truly should consider yourself partially female. the rating on the tire is the max psi that the tire can run safely. always consult the side of the door or the owners manual for the pressure that car was designed to operate safely
Well i actually checked my tire pressure, I thought it was low.. well i was WAY wrong, one tire was at 40, the other was at 37.. and thats straight from the factory...lol.. no one has ever put air in it
DANRICKARD
10-01-2015 12:08 AM
