2.4l coolant temp problem
Old 11-21-2008 | 03:58 PM
Cloudio's Avatar
iam so frustrated were to begin!!! basically my coolant temp. sensor was bad or atleast i thought it was because periodically the coolant temp would read --- but i replaced the sensor yesterday and this morning on the way to work ....what do you know!!! goddamn temp reads ---- and that noisy ass secondary fan comes even from a cold start ......after replacing the sensor i thought well **** maybe its the pcm ......so i took out the vector tuned one and popped in my oem stock pcm ...i thought i had nailed it but now it just did it again WTF!!!!! IS WRONG
please help guys: cussing::cussi ng:
bbumpp
Old 11-21-2008 | 04:02 PM
invisible's Avatar
You iz to funny.
Old 11-21-2008 | 04:50 PM
Dunkinuts's Avatar
what is your problem? it is displaying [ --- ] or is it blank?
Old 11-21-2008 | 05:24 PM
slowswap's Avatar
Thermostat.
Old 11-21-2008 | 05:47 PM
Cloudio's Avatar
its displaying (coolant temp: ---) i replaced the sensor ....does the same thing .....is there more then one coolant temp. sensor ...i mean at this point thats the only other thing i can think of any ideas??
Old 11-21-2008 | 05:49 PM
SymbioteLT's Avatar
could be a damaged cable
Old 11-21-2008 | 05:51 PM
Cloudio's Avatar
Originally Posted by invisible
You iz to funny.
thanks bro...Iam glad you found humor in my frustration, your response has already helped the issue "sarcasm"
wouldn't expect that from a premium
hmmm damn i didnt think of that ill take a look let you know what i find thanks
Old 11-21-2008 | 06:03 PM
slowswap's Avatar
My friend has this problem. The ECU spits out failing thermostat. Replace it.
Old 11-21-2008 | 06:14 PM
Cloudio's Avatar
i already did didnt cure anything hence the frustration lol
Old 11-21-2008 | 06:16 PM
slowswap's Avatar
All you said was temp sensor and ECM, not thermostat.
You should clarify next time.
Old 11-21-2008 | 06:17 PM
BlilBT's Avatar
bbumpp
My wifes has been doing it on & off also,
Causes
1) Air filter is dirty, I blew my wifes out with air & it was fine, Make sure to also clean the tube & sensor
2) check & the secoundary fan is running & not the primary the car thinks it is over Heating
3) I disconnected the battery & it went away!
4) Dirty injectors can als make it do it
5) Not running the recommended octane>> Which my wife was putting in 87 when gas was high & Not what is recommended by GM, when I found out she was running it I made her switch back & did the above & it went away for a year.
Whats funny is it is now doing it again & last time it was cool out just like now! But I never replace the filter & it is do!
The way it's programed the whole system is tied together & it could be several things, But like I stated most likely it's the Filter!
originaladrian's Avatar
LMAO!!! u really think higher of premium members? i used to be premi but not anymore. u wont take my advice?
it might just be the connection to the display. or a bad thermostat.
Old 11-21-2008 | 06:31 PM
Cloudio's Avatar
point taken lol hold on lets clarify some cause iam not sure ...what are you referring to when you say "thermostat" are you talking about the coolant temperature sensor ????
Old 11-21-2008 | 06:41 PM
slowswap's Avatar
Thermostat as in the thermostat. It's what controls the amount of water flowing through the engine to allow the engine to warm up and then stay at operating temperature.
Old 11-21-2008 | 07:03 PM
Red07SSNA's Avatar
Thermostat controls the engine coolant temperature. It is a heat sensitive valve that opens when it reaches a predetermined temperature. It can go bad in that it doesn't open resulting in overheating -- OR -- it stays open which causes the coolant to flow through the engine too fast and is cooled too much via the radiator so your engine doesn't get up to the proper temperature. When your temperature displays 200 degrees for a few seconds and then drops down to 190 degrees it is due to the thermostat opening. The thermostat should be closed when the engine is cold so there is very little flow of the coolant to allow it to warm up quickly -- when it reaches the correct temperature the thermostat opens and the coolant begins to flow.
Old 11-21-2008 | 07:10 PM
Cloudio's Avatar
that must be the problem...how much is a new one??? part #???
Old 11-21-2008 | 07:14 PM
this is going to sound very stupid. but did u check all ur fuses?
and thts totally serious BTW lol
Old 11-21-2008 | 07:15 PM
DebadgedBALT77's Avatar
i dont think the thermostat is the problem
Old 11-21-2008 | 07:47 PM
Red07SSNA's Avatar
GM Part numbers:
2.2/2.4: 90537453 (seal included)
2.0: 21018811 (includes 2 seals)
Here's a shot of the location(2.0 engine -- 2.2/2.4 similar):
https://www.cobaltss.net/gallery/fil...thermostat.jpg
Old 11-21-2008 | 07:52 PM
i would get it checked out first... might be something pretty simple...
also, u would prob throw a code if it was ur thermostat
Old 11-21-2008 | 07:55 PM
LS6Rally's Avatar
my 2.4 did this i took it to a dealer and they could find the problem. havent had it happen in months though. good luck.
Old 11-21-2008 | 07:56 PM
Red07SSNA's Avatar
I would think so too....if the DIC shows a message there is most likely a DTC recorded. Get it scanned and the DTCs read.
Old 11-21-2008 | 08:02 PM
Cloudio's Avatar
alright guys ....iam gonna get it checked out .....thank you ... ill keep you guys posted
Old 11-21-2008 | 10:24 PM
LS6Rally's Avatar
the dealer said nothing came up. i checked it at midas where i used to wrk and i got nothing. what really bothers me is if the car doesnt know the temp. then why doesnt a light come on on the dash to warn you??? i thought it should. esp for someone who may own teh car who knows nothing about cars.
Old 11-21-2008 | 10:27 PM
a bad thermostat wouldnt cause the display to show ---. the ar would still be able to read the temperature if the t-stat was fucked up. Id say you have an electrical issue( obviously) possibly a short in the circuit that leads from the temp sensor to the ECU?/ BCM. i cant remember where that leads to on the cobalt
Quick Reply: 2.4l coolant temp problem
