2.4l COOLING PROBLEM ?
Old 04-18-2008 | 06:23 PM
Cloudio's Avatar
hey guys for 2 days now when i use my car the secondary fan comes on and stays on and the coolant guage shows this {Coolant Temp: ------} whats odd is it happends the second i start the car in the morning even after a full night of no use ?!?!@
anyway periodically during the day the secondary fan will shut off and the gauge will read normal temps such as {Coolant Temp: 185*} put that usually only lasts in 10 minute spurts and then its comes back on and the gauge reading disappears
-There is plenty of coolant in the system
Any ideas .... iam all out
Old 04-18-2008 | 06:28 PM
XM15's Avatar
Bad sensor?
Old 04-18-2008 | 06:36 PM
Cloudio's Avatar
Originally Posted by XM15
Bad sensor?
Not sure ... but the more i read my own post the more iam leaning towards that aswell lol
Old 04-18-2008 | 06:40 PM
XM15's Avatar
It should still be under warranty, right?
Old 04-18-2008 | 07:32 PM
Turbo06Sedan's Avatar
Well, in my own mental thinking of theory. (assuming i were to design a car)
if the car cant sense the coolant temp, id want it to kick on the fans to full too, just incase you were to run hot.
Its covered under warranty.
Hell, I have a turbo kit, yet the dealership still fixed all my coolant issues.
Old 04-18-2008 | 07:58 PM
LS6Rally's Avatar
mine has the same problem and i cant get it to duplicate when i go to the dealer. but you would think a warning light would come on if it has no idea of the temp? irts got to be a sensor and teh sedning unit is fine to the PCM or the coolant temp warning light would iluminate. i just went over waranty and this is happening to me for about a month. let me know if you find something. good luck
Old 04-18-2008 | 08:20 PM
CobaltChikara's Avatar
This may be due to a bad thermostat. I can't see any other reason why it would be doing that.
Old 04-19-2008 | 08:07 AM
LS6Rally's Avatar
if it was a thermostat the car might not run right (heat up) and the temp would still read somthing
Old 04-19-2008 | 11:39 AM
Cloudio's Avatar
huh ...ya its still under warranty but note that the car runs fine... ample power wether the fans on or off ........so it probably just the sensor .... ya i think i might just bring it in
Old 04-20-2008 | 12:28 AM
wordsthatiwrote's Avatar
Talking
your car is just so visually hot that it HAS to run the fans all day so it doesnt bake you alive inside.
dennis69
10-20-2015 04:49 PM
DocSvensk
09-27-2015 02:24 PM
Adiaz1ss
09-26-2015 11:51 PM
09-26-2015 06:44 PM
Quick Reply: 2.4l COOLING PROBLEM ?
