2.4l injectors
2.4l injectors
Hi
I currently have the problem described in this tsb and the Cel constantly pops on and off https://www.cobaltss.net/forums/show...&highlight=tsb
I live in Canada and the dealer is asking a small fortune for the 4 injectors so i would like to know if it would be possible to replace them with some aftermarket ones and repair the problem?
I think the stock ones are 24#...
Thanks for your help!
well depending on what year your car is, you should have powertrain warranty if its an 06 and up. But mind you lots of the 06 warranties are starting to expire, mine just passed in june. if not, then you should be able to get them from gm directly, and if thats too pricey for you, there are other injectors out there and you can even go for a bigger injector.
Yeah i have the 100000km warranty on powertrain but the injectors are not covered, thats what the dealer told me, the dealer wants 85$ per injector plus the reflash.
I checked on gmpartsdirect and theyre like 30$ each but i live in Canada and they wont ship here... so im just looking for the cheaper alternative
Does anyone know if accell injectors #150124 would fit? They are high impedance injectors
