2.4L Performance Modification List
Old 11-03-2008 | 02:36 PM
  #101
elecblue06's Avatar
Originally Posted by rockstar014
we need to find upgrade for our 2.4s lol
we'll have another FI setup once i finish .. complete with tune
Old 11-17-2008 | 10:22 PM
  #102
dsp86's Avatar
JBP also has cylinder heads for the 2.4 stage 1, 2 and 3
Old 11-25-2008 | 03:57 AM
  #103
kush's Avatar
do cams help if we're turbo'd?
Old 11-25-2008 | 07:48 PM
  #104
elecblue06's Avatar
if you have the correct grind definitely
Old 11-26-2008 | 01:37 PM
  #105
rockstar014's Avatar
put zzp turbo kit on there
Old 11-26-2008 | 01:55 PM
  #106
elecblue06's Avatar
you get that bish on ?
Old 11-28-2008 | 03:31 AM
  #107
kush's Avatar
what are options for the cams? There's the JBP triflow ones, are they just a special way of grinding them...or is grinding our stock set different?
Old 02-01-2009 | 10:13 PM
  #108
Red07SSNA's Avatar
Another update:
LSJ Downpipe/Cat -- cat is 60% larger than the 2.4 Cat.
Appears to be a perfect fit for manual equipped 2.4s But needs reworking by an exhaust shop to install in an automatic equipped 2.4. No CELs either.
Stock 2.4 DP pipe is 2" OD
LSJ DP pipe is 2 3/4" OD
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/2-4l-auto-dp-vs-lsj-dp-150651/
Old 02-01-2009 | 11:54 PM
  #109
elecblue06's Avatar
we pretty much have the JBP or custom the JBP wont be the best fit for turbo as they're made for NA
Old 02-28-2009 | 10:55 AM
  #110
riko540's Avatar
Please add the ZZP turbo kit. Here's the link to the site: http://www.zzperformance.com/cobalt_...=922&catid=143
And here is some more info: https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/2-4l-zzp-turbo-kit-sneak-pic-151788/
Thank you
Old 02-28-2009 | 12:33 PM
  #111
WhiteSSBalt's Avatar
Not a Sebring
Heres some more things that I noticed that weren't on the list:
Weapon-R secret weapon intake (short ram intake)
http://weapon-r.com/english/index.ph...oducts_id=5425
Shiney-Hiney header (shorty header)
http://www.shiny-hiney.com/header.html
Old 03-08-2009 | 10:04 PM
  #112
MannyP's Avatar
does doing a tune void the warranty? i have an auto and want to get some gains
Old 03-08-2009 | 11:32 PM
  #113
_UnLiMiTeD_'s Avatar
yes a tune voids the whole powertrain warranty
Old 03-08-2009 | 11:52 PM
  #114
elecblue06's Avatar
not so much.. tune will only void the warranty if there is a reason it is the cause.. and the thing thats great about tunes ... is they can be put back to stock
Old 03-09-2009 | 12:19 AM
  #115
Dunkinuts's Avatar
this kid still hasn't added much of the JBP stuff.
Old 03-09-2009 | 12:24 AM
  #116
They can still tell if the ecu had been modified, so yes if they see your ecu had been played with, it voids it no matter wat, doesnt have to be the cause of the failure. The only real way to get away with it is grab a second ecu, put the tune in that one, then if all goes bad, put back the stock non modified ECU and take it in.
Talk to a GM tech
Old 03-09-2009 | 01:09 AM
  #117
elecblue06's Avatar
Talk to a GM tech
dude.. i have talked to a gm tech... according to him ( unless he was full of ****) tech 2 doesn't read ECM history.. so when you're CURRENTLY flashed with a tune they can tell but if you flash to stock they cant..
and no.. it doesn't void it no matter what.. my dealership has known for ages that I have a tune to turn off the CEL from my high flow cat.. and I haven't had any issues..
Old 03-09-2009 | 01:31 AM
  #118
All depends on the dealership, but most will void u right away if they see the tune. Just because your dealership does it does not mean the rest do. Infact its rare to find a dealership that will approve warranty work or even look at it if they know its tuned.
There was a lot of talk at our last meet over this issue, in the end, if the dealership is determined enough to find a way to void u and u tuned ur stock ecu, even if its tuned back, they can find out.
Old 03-09-2009 | 02:24 AM
  #119
Not a Sebring
Or much of anything in general.....
I wish the mod had stickied my 2.4 performance modifications list thread I made a looong time ago. It was more complete than this list, AND I practically live on here so it would be constantly updated. Owells, it was overlooked by the mods, so this one will have to do.
Old 03-09-2009 | 02:48 AM
  #120
elecblue06's Avatar
ok
maybe in canadia things are different.. and tech 2 can read history.. but as far as my experience with it .. they can't
as long as the tune hasn't effected things to damage them.. then they legally can't deny anything.. just because my cars tuned doesn't mean my sunroof was modded.. if you pop your engine.. and they know you had it tuned.. yes .. you will lose warranty.. but if your catback breaks or something no they can't
Old 03-09-2009 | 02:59 AM
  #121
sunroof isnt power train, i said powertrain not bumper to bumper
Old 03-09-2009 | 03:24 AM
  #122
elecblue06's Avatar
... i know that.. nevermind. it's not worth it..
  #123
alright then..
Old 03-09-2009 | 03:35 AM
  #124
Not a Sebring
Be nice boys and girls......
Old 03-09-2009 | 03:41 AM
  #125
elecblue06's Avatar
exactly why i'm stopping lol
Quick Reply: 2.4L Performance Modification List
