2.4L zzp turbo issue
Old 06-28-2010 | 08:53 PM
DFZ24's Avatar
I have an small issue with the zzp stage 2 turbo kit,
I would like to know if anyone knows a solution or if anyone have or seen this issue.
-After installing the kit the speedometer doesn't work, due to this a code came up about the power steering, also coming up in the DIC.
-the person that installed the kit says it could be due to the heavily modified pcm, wrong pcm, different pcm or something else. not sure
cars runs about right, the DP is not connected to the exhaust due to a difference size and flange, flange could not be found anywhere so a custom will be made.
this is what i can remember till now
any question feel free to ask
thank you
Old 08-01-2010 | 10:10 PM
ducky07_419's Avatar
the power steering light is a recall they put out...but don't know about the speedo
Old 08-02-2010 | 08:14 PM
kxrida2000's Avatar
thank you
my speedo did the same thing and i still havent found a solution
Old 08-02-2010 | 08:22 PM
07SuperchargedSS's Avatar
Definately not buying this kit now!!! Good luck with fixing your issue man, that really sucks
Old 08-02-2010 | 08:25 PM
Zdeuce4's Avatar
do not think its the kits fault.
zzp is a trusted company. call them, email them . just do something
Old 08-02-2010 | 08:27 PM
mmcgee123's Avatar
Maybe it's the wrong computer I personally love my kit but I didn't use there PCM
Old 08-02-2010 | 08:34 PM
riko540's Avatar
It could be I wonder if the 08 PCM is different from the 06-07
Old 08-02-2010 | 09:30 PM
kxrida2000's Avatar
it would have nothing to do with there kit man because this happened to me and im a 2.2 tuned by trifecta
Old 08-02-2010 | 10:27 PM
mmcgee123's Avatar
The computers are diffrent 06-07 hense why I can't do hptuners
Old 08-03-2010 | 10:41 AM
DFZ24's Avatar
ok the problem with the speedometer was fixed, it was their pcm, really fucked up tune lol dont know why, i emailed them and they emailed me a new tune.
it was an acceptable tune, italianjoe did a touch up (well a good touch up on the tune and the car runs completely different) much better.
now i have this issue. engine lights comes up as P1682 Ignition 1 Switch Circuit 2 ECM, PCM
ZZP is telling me is the intecooler pump, italianjoe is telling me is possible the same thing because is pulling alot of power from it, but the intercooler was connected as instructions indicated.
I research and ppl had the same issue and resolve the issue, but they didnt said have to fix it just found the problem ( that was the intercooler connection) so i dont know where to connect the intercooler now.
on and the power steering, i send the car to dealer and boom done lol. my power steering was going off and on, all of the sudden the steering will get hard to turn. but fixed by recall.
^^^ yeah i advice ppl to do this, tell them to email you the tune.
Old 08-03-2010 | 04:37 PM
mmcgee123's Avatar
U most likely wired ur intercooler pump thru ur engine fuse block didn't u I had the same problem if that block gets to many ohms of resitwnce thru it it'll throw that code and go into limp mode
Old 08-04-2010 | 01:13 AM
DFZ24's Avatar
i think it was install to a cable that was indicated in the instructions, dont remember which one, the person that installed it told me.
to what you connected the intercooler pump???
Old 08-04-2010 | 10:20 AM
mmcgee123's Avatar
make sure its wired correctly i had a nigtmare with mine i ended up wireing mine to the main fuse block in the car on the passenger side kick panel had the same codes and issues ur having so id make sure its set up correctly
Old 08-04-2010 | 01:49 PM
Maven's Avatar
where are you guys wiring your pumps to?
Old 08-04-2010 | 06:37 PM
kxrida2000's Avatar
where should it be wired to then?
Old 08-04-2010 | 06:43 PM
conerboner's Avatar
It says in the instructions to hook it up to the abs wire. I found a fuse in the fuse box in the engine bay that had power with the key on only. It ended up drawing too much power from the ecm and the throttle body would not stay at the position it was supposed to be at. I used a relay and that fixed the problem.
Old 08-04-2010 | 06:49 PM
EcoTecDriver's Avatar
I have mine on a add a circuit on the fuel pump fuse, Should I change it? and how would I wire the relay?
Old 08-04-2010 | 07:03 PM
mmcgee123's Avatar
Just run a wire to inside the car and there's empty ports in the fuse block on the passenger side that has key power that's what mines wired to
Old 08-04-2010 | 07:08 PM
its okay I looked at a relay I have and figured it out, its needs one positive running to the blade 85 and then coming out blade 87 on the relay to to 12v
Old 08-04-2010 | 07:10 PM
mmcgee123's Avatar
I wouldn't mess with the fuse block in the engine compartment I had a bad experience just sayin
Old 08-05-2010 | 02:01 AM
DFZ24's Avatar
thats what is happening to me, sometime the throttle body will go between 2-3k rpm when im slowing down in neutral. which one you put the relay on? did it took the engine light off (code)???
mine are wire to the abs like it says
mmcgee
where is the fuse box that you connected to???? inside or outside? you had to extend the wire of the pump right?
Old 08-05-2010 | 09:57 AM
conerboner's Avatar
Mine was in limp mode so I might have been having a different problem than you. I couldn't even drive my car except to get on and off the rack at my dad's shop... I had two codes for the throttle body and when I put the relay on everything worked great. I'm still throwing a lean code but my afr's look good so I just ignore it now...
Old 08-09-2010 | 01:38 PM
mmcgee123's Avatar
Inside the car on the passenger side on the left
Old 08-09-2010 | 01:45 PM
mrgrinch's Avatar
sub'd, i want one of these kits and knowing the issues ahead of time is good! hope you get all the bugs worked out
Old 08-09-2010 | 01:51 PM
mmcgee123's Avatar
Mine is perfect everyhthing works great and it pulls like q train
Quick Reply: 2.4L zzp turbo issue
