2.4's with i/h/dp/e and tune look here
The word I am looking for is:
GINORMOUS
Yay for reading.
He said a tune as well.
GINORMOUS
Definatly will feel and get gains. I bumped up 10whp and 10 wtq on the dyno with only intake and exhaust. Could only imagine and what the header and downpipe will help. Mine was on a mustang dyno as well
once you can tune those will go down considerably. Mine are somewhere around 70 i believe. Stock injectors are fine for bolt-ons. When you go boost or start adding cams ontop of bolt-ons and start getting close to the 200whp mark then you need to upgrade the injectors.
Well it is a must for this car. GM should be ashamed of the lame ass stock tune on the 2.4 cobalt, it really is uncalled for bad. VMS Did a great job for a mail away tune. If you have an Auto definantly send in your tcm too. The difference is night and day. I honestly gained 2 mpg someware in the ball park of 15-20 whp and the 2.4 bog dissapeared. My car now breaks em loose a bit when the power enrichment hits needless to say im very pleased with it.
You can lean the AF out a little and reduce the duty cycle, but it still goes up there on some cars. It depends on mods. But the way they have them from the factory they are not tuned well and are running higher IDCs.
GM High Performance tested the 2.4SS and mentioned that with an improved AFR the 2.4L should make better power. I've still never felt anything that impressed me on the 2.4L except for the auto tranny tunes, but they feel slow compared to most of the others cars I tune.
