224whp / 211tq
#102
Welded another bung in about 6" down from the narrowband o2, same position before the cat. There's a couple more things I want to try before I give up on the thing though. I am going to try to re-ground again (2nd time), another free-air calibrate, and pull the sensor out, wipe it down and see what it does after that.
#105
#110
#111
I completely skipped over that part. I saw the 224 and my smile turned upside down. I was thinking about getting an SC for my 2.4. If I get the M62 Eaton I will be upgrading to Stage 3 ASAP. Aiming for 350whp. Keep in mind its stage 3 and I already have all the bolt-ons and can get a fine-tune for about $100. It'll be tough but I can make it happen. Meth injection will be next after that lol.
They should make a kit of the Eaton M62, I'd buy it.
#112
Jimmy--Not using the 2.0 TB yet. Might try that tomorrow though. That's the 2.4 TB you see there.
#113
So bigworm and i have the 42.5's Injector Duty Cycle at 79% on the stock sized pulley at 6400rpm. Basically if you want to run anything smaller than stock sized pulley you'll need 60lbers
#115
I was thinking the same thing pat. not too many people have even hit 300 on the s/c bolt i think it would be a decently amount harder on a 2.4 seeing as the motors not even built for it from the get go.
#117
#118
No wasn't me. I was in email contact with them though. I got a defective filter with the original packaging and had to send it back, and they sent me a new one (filter).
#119
Oh, there was a guy putting an M62 on the LE5 on the phone w/ them when I was there. Who woulda' known there was more than one of you in communication w/ them around the same time. Oh well, nice choice anyways!
#121
OK ok ok ok .... i know i dragged my feet with this. I apologize just been swamped with work and moving into our new shop. ANYWAYS... here is the dyno vid... of the quietest supercharged car ever
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i112.photobucket.com/player.swf?file=http://vid112.photobucket.com/albums/n180/smgautosports/100_0836.flv"></embed>
