91 octane benefits?
Old 05-22-2008 | 03:10 PM
Panici's Avatar
91 octane benefits?
Hey guys, just wondering if there are any benefits to performance when running 91 octane in a stock 07' SS.
I just had enough 87 in the tank to get me to the station, and since my tank was pretty dry, i figured why not try some 91. I put in a little over half a tank just to test it out.
Old 05-22-2008 | 03:11 PM
invisible's Avatar
93 would be even better unless you're like me and can only find 91
Old 05-22-2008 | 03:12 PM
thedubsack85's Avatar
the higher the octane the harder is it to burn but you get more energy..
chris88z24's Avatar
91+ is what the ss s/c is tuned for from the factory.
Old 05-22-2008 | 03:19 PM
Dunkinuts's Avatar
it turns into a rocket ship!!!! 93 all day here!!! but i did pay $4.07/gallon last tank
Old 05-22-2008 | 03:21 PM
Mr McCabe's Avatar
I believe its tuned for 93 octane. Someone correct me if I'm wrong.
Old 05-22-2008 | 05:14 PM
SCOTTA504's Avatar
So after looking through the threads... putting 92 (speedway) in for a stock ss/sc will be fine? I know 93 is what is recommended with stage 2 but I was wondering about stock?
Old 05-22-2008 | 05:16 PM
XM15's Avatar
92 should be fine.
Old 05-22-2008 | 05:45 PM
maverick0716's Avatar
You're not even supposed to put 87 in the 2.4L SS.........definitly not in the SS/SC. I've run 92 in my G5 GT since day one. The computer on the 2.4L does go into low octane mode, which pulls timing to protect the engine, but there definitly would be a power loss.......most likely slightly worse gas mileage as well.
Old 05-22-2008 | 05:47 PM
UmeNNis's Avatar
Wrong and wrong... the SS/SC is the only Cobalt that 'recommends' 'premium' (91+) octane fuel in it; and even with the SS/SC, you CAN run 87 all the time if you wish, and the computer will just pull timing automatically.
Old 05-22-2008 | 05:51 PM
LMAO, I could go photocopy my damn manual if you really don't believe me. You don't even own a 2.4L so don't come in here spouting your great knowledge on 2.4Ls.
Old 05-22-2008 | 05:59 PM
bigworm's Avatar
Don't you know owning a LSJ makes you god? WTF is wrong with you little 2.4L owners!
so tired of these octane and spark plug threads... can we get some gawd-damn stickies in this forum?
Old 05-22-2008 | 06:00 PM
Panici's Avatar
So the 2.4L is factory tuned for 91?
Old 05-22-2008 | 06:04 PM
Yes, the 173 hp is with 91 octane fuel. I believe the quote from the manual says "91 octane is highly recommended but not required"
Old 05-22-2008 | 06:09 PM
Beck's Avatar
the 2.4 does indeed reccomend 91 octane. Try to argue with me, i dare you haha.
Old 05-22-2008 | 06:10 PM
Zdeuce4's Avatar
I quoted the manual in a previous post
Originally Posted by zdeuce4
manual says " IF your vehicle has the 2.4 or the 2.0 sc use premium uleaded gasonline with a posted octane rating of 91 or higher. You may also use regular unleaded gasoline rated at 87 octane or higher, but your vehicle's acceleration may be slightly reduced, and you may notice a slight audible knocking noise, commonly referred to as spark knock. If the octane is less than 87, you may notice a heavy knocking noise when you drive. IF this occurs, use a gasoline rated at 87 octane or higher as soon as possible."
u can run 87 fine. i recently did it for about a month just to test it out. gas mileage hasn't suffered too much, but u can feel the acceleration difference. it's not too bad, but i wanna tune soon and i want everything where it should be
Old 05-22-2008 | 06:15 PM
Panici's Avatar
Jesus, i've been using 87 since we got the thing. I could have sworn the manual says 91+ is only required on the SS/SC, but I guess i am mistaken.
Just did some pulls with 91, and there is a noticeable difference.
Also a 'friend' was also doing the same thing as me, and this 'friend' just installed a ShiftPlus, and let me tell you 91 + ShiftPlus = CRAZY! (compared to 87 and stock)
Old 05-22-2008 | 06:23 PM
bigworm's Avatar
LAIR!
Old 05-22-2008 | 06:26 PM
Beck's Avatar
Originally Posted by bigworm
LAIR!
worm dont make me come over there and **** up the rear of your car too
Old 05-22-2008 | 06:27 PM
Panici's Avatar
LAIR!
I just got off my ass and the manual DOES say for both the 2.0 AND 2.4 that 91 is what to use.
It says you can use 87 but it will reduce power (ie. pull timing)
Old 05-22-2008 | 06:28 PM
afterlife04's Avatar
So ultra 94 or 94 Gas would make the car go faster then 91?
Old 05-22-2008 | 06:31 PM
Beck's Avatar
no, the car was tuned with 91, so anything over that isnt really benefiting.
Old 05-22-2008 | 06:33 PM
so no extra mileage etc.....from the 94 :|
Old 05-22-2008 | 06:35 PM
Beck's Avatar
negative
Old 05-22-2008 | 06:50 PM
bigworm's Avatar
too soon. too soon.
Quick Reply: 91 octane benefits?
