AEM wideband
Same, except I used an empty fuse spot. Make sure to solder + cover all your connections too if you use the fuse box in the passenger footwell. I didn't the first time around and came VERY close to shorting the wideband power wire with all the **** down there.
You are going to have to trim the inside of the pillar for an AEM gauge to fit, the SS/SC pillar has some strange plastic part that is not on the base. I did it with a box cutter, doesnt have to be pretty, youll never see it again haha
n20saturn
09-30-2015 12:26 AM
