Anyone running forged internals at 9:1
Old 12-21-2012 | 12:33 PM
pjk91's Avatar
in their LE5s? What rods/pistons did you go with? What's the labor cost associated with this (roughly)?
Old 12-21-2012 | 01:00 PM
noorj's Avatar
I think hhrfreak had low comp pistons in his 2.4, could be wrong though. I know the low/mid range will feel a bit more sluggish but I'm not sure if it would pay off in power gains. Depends on the fuel you want to use also
Old 12-21-2012 | 04:13 PM
pjk91's Avatar
91 octane is all we have out here in CA. You can be more aggressive with timing at a lower compression. Cylinder temps will be lower increasing reliability at higher boost. I've been running 9lbs since 2007, and it's still strong but I'm not sure I want to risk it with a GT3076 @ 15-17psi.
Old 12-21-2012 | 04:50 PM
OttawaMark's Avatar
The JE 9.0 and ZZP forged rods are actually 8.8CR, labour can be steep if you don't reuse the stock rings as you will need a rough hone of the bore to remove glaze. I ordered the zzp forged block and had zzp take care of everything. Piston to bore clearance is another issue, impossible to judge until you actually measure it. I personally wouldn't order pistons without being custom fit to my actual bore #s, but I've already blown one build due to piston slap, install error etc.
You can order 88mm bore 9:1 slugs and rods, install and hope you have no problems but it gets expensive fast if you don't get a little lucky on the piston to bore clearance.
Freek and I both rebuilt our bottom ends, he got luckier than I but still spun a rod bearing and he had compression/leak down issues and we both ended up selling our blocks for scrap. Mine pretty much right away and his within 6 months. A first time do it yourself job this ain't.
Old 12-22-2012 | 09:10 AM
hhrfreek's Avatar
Live and learn. Wouldn't do it again myself. If I ever recoup my fun money after that fiasco, I can tell you I won't be tearing into my LNF myself. Having it done professionally is a very good idea.
Consider a forged block from ZZP and save a headache. At 17psi you are getting to the point where you can break a sleeve on a stock block at some point. I know good tuning goes a long way, but your forging parts to make more power and eventually you will get a little knock and at that power level say good bye.
Old 12-27-2012 | 12:29 AM
IonNinja's Avatar
Building the bottom end is not hard and can be done with the motor in the car.
Just get a buddy that knows what he's doing (aka has done this before) to help and you'll be fine
Got 480 miles on my rebuilt L61 and I'm expecting it to last *knock on wood*
Old 01-05-2013 | 09:17 AM
mmcgee123's Avatar
I'm in the process of building mine I have je pistons zzp rods n girdled block lots of boost lots if e85 lots of timing lol should be fun
Old 01-05-2013 | 09:24 AM
BankerBalt's Avatar
My motor was the first I ever tore apart and rebuilt. I have no issues at all
turbochargedss2012
09-20-2023 12:17 PM
Zharrington_2010LNF
02-08-2016 01:43 PM
01-12-2016 12:01 AM
ineedacobaltss
11-07-2015 02:25 PM
dieGone
10-01-2015 06:27 PM
Quick Reply: Anyone running forged internals at 9:1
