B&M install help 2.4
Old 11-08-2007 | 11:52 AM
Viper33884's Avatar
Originally Posted by OrngBalt
I have the GMPP intake so there is no room for the mount.
Nope which sucks but I would get the Injen and try the Ingalls out.
Originally Posted by cougar2588
how much does that ingalls run compared to the mounts?
Mounts now I think from TurboTechRacing are like $40, and the Ingalls is like $160 shipped from CobaltPerformanceParts.com I believe.
Old 11-08-2007 | 12:03 PM
OrngBalt's Avatar
thats ok... im perfectly content.
Old 11-08-2007 | 12:29 PM
Viper33884's Avatar
OK... I was trying to get some comission from TTR....lol j/k.
Old 11-08-2007 | 01:37 PM
OrngBalt's Avatar
Now, If they could find a way to come up with an engine mount that fit with everything else in place.... well then I would buy something.... hint hint hint
Old 11-08-2007 | 02:23 PM
Viper33884's Avatar
Lol yea that would be nice for the stocker intake guys....
Old 11-08-2007 | 02:39 PM
TurboTechRacing's Avatar
Our mount is VERY close to the same size as the stock mount. Has anyone actually tried to use a stock air box on a 2.2/2.4 and the TTR mount?
Old 11-08-2007 | 02:41 PM
Viper33884's Avatar
From the post you made when you first released them only one's with aftermarket intakes...sorry.
Old 11-11-2007 | 01:18 PM
BodMonPullUp's Avatar
Are the mounts easy to install?
Old 11-11-2007 | 03:38 PM
Jimmys2007CobaltSS/C's Avatar
so this b&m is really worth it and will make it qicker..?..im deciding if i still want to keep my ride or not
Old 11-11-2007 | 08:38 PM
Viper33884's Avatar
Not to hard, just a standard floor jack and a vise.
Well not to much quicker but no more delay between shifts and also the quicker shifts cuts down on the friction in the trany so it runs cooler.
Old 11-18-2007 | 05:27 PM
  #36
Evil C's Avatar
Just installed the B&M Shift plus On the 2.4 you splice the red from the B&M Shift plus to the orange with black stripe that is not braided with a another wire from the transmission harness. And the black from the B&M with the light blue with a grey stripe.
I gotta say it was a cinche to install I only reccomend you use a dowl rod or a wire hanger or somthing similarly long slender and ridged because it will save a ton of headaches with going through the fire wall.
Its pretty nice firms up the shifts quite nicely.
05-28-2022 03:47 AM
dennis69
10-20-2015 07:39 AM
patooyee
10-15-2015 05:11 PM
justinchinn
10-02-2015 12:18 PM
Delta coupe
09-30-2015 08:11 AM
Quick Reply: B&M install help 2.4
