Badmab install
Old 01-07-2013 | 11:19 PM
chevygirl2006's Avatar
I noticed a sound difference. The car seemed to run a little better after.
Old 01-08-2013 | 10:09 AM
StevoElSupremo's Avatar
Originally Posted by 06Cobalt2.4
My car has 113k to the frame, 64k to the motor, and I installed an aftermarket header on my car around 104k to the frame and motor (before the swap), and yeah they were rusty, but honestly I wasn't too worried about snapping bolts. The only issue I had was after about 4k miles on my aftermarket header, my downpipe gasket (no-cat or resonator) blew 2 of the studs completely off. Too much racecar I guess. Anyway, that's the only issue I really had, and just took the remaining bolt to a True Value Hardware store and patched it all up with 2 new bolts and nuts costing ~$5.00 total. After all that and about 10k miles more, my main header gasket finally blew a couple of weeks ago, and I just got a Genuine GM one to go right back. Debating whether to take my header off and line up the gasket and use a drimmel to bore the collectors to 1.65" or not.
Originally Posted by hhrfreek
They didn't ******* blow off, troll...You didn't tighten them enough and they fell out.
Dumb + rotary tool = stupid new thread.
LMFAO HHRfreak thats exactly what I was thinking
but yeah I have a badmab header on my car, have had it for 20,000K and my car+engine has 140,000KM on it and I have no exploding studs to report of
Old 01-08-2013 | 10:11 AM
breds2k's Avatar
Just got a ZZP midlength combo for a STEAL! might be a bit before I install them but the guy said his gaskets are ****, so do you guys my 07 with 80k gaskets will be ok or order new ones from the dealer? Wont really know till I check it out, but dont want to get stuck in a project.
Old 01-08-2013 | 03:42 PM
I re used mine at like 90k
Old 01-08-2013 | 09:35 PM
CordiaDOHC's Avatar
The header should come off fairly easily. Hell Ive done 3 headers on my 2.4 lol. 2 of them Ive done the header from the top. Ive gotten to the point I can swap the downpipe in 15 minutes using a jack and 2 stands and the header (shorty) in about 10 minutes. lol
Old 01-08-2013 | 10:42 PM
Pitbull2o08's Avatar
Dude you need to teach me!
Old 01-08-2013 | 11:37 PM
I re used my header gasket at around 60,000 miles and its fine, no leaks
Old 01-09-2013 | 12:23 AM
noorj's Avatar
Haha i feel you on that one, Ive changed mine about 6 times. The first time I thought it was such a bitch now its like muscle memory.
I wasn't a fan of the bad-mab though, he can't seem to use a jig correctly or just puts so much heat into them every flange just gets warped. I went through two with this problem. Love my ZZP longtubes now tho
Solaris99
28
03-15-2017 01:22 PM
dennis69
10-20-2015 07:39 AM
justinchinn
10-02-2015 12:18 PM
Delta coupe
09-30-2015 08:11 AM
Bohb
09-27-2015 09:11 PM
Quick Reply: Badmab install
