Beck's Latest Supercharged 2.4 Build
Old 05-20-2013 | 01:17 AM
  #51
Tjolley's Avatar
Ur valve cover turned out sweet i like the finish might buy some clear coat now
Need to blast my sc next time im over ur way.
Might do it wen we tune u for e85 and release the beast.
Old 05-21-2013 | 01:28 AM
  #52
Beck's Avatar
sounds good. I'm pleased with the color. Pictures dont even do it justice
Old 07-13-2013 | 10:04 PM
  #53
Tjolley's Avatar
Gettin his car dialed with the 80s on gas.
Had a few issues with warm starts found out the 80s were drowning it lol so after some messing with it it fires right up.
Did alot of loggin in the hills in and out of boost alot and the temps stayed below 125 the entire time i was pleased.
We will continue with some WOT tuning once he gets the tank of bad gas out.
Old 07-13-2013 | 10:07 PM
  #54
SalvageBaltSS's Avatar
nice car to the OP. may I ask how much he has in the build total, car, mods, etc .
Old 07-17-2013 | 10:33 PM
  #55
Beck's Avatar
Probably around 2500-3k total in performance mods.
Old 07-18-2013 | 09:58 AM
  #56
Tjolley's Avatar
Ya and theres nothin half assed eather. Everything is 100%
Old 07-20-2013 | 11:24 PM
  #57
davev9150's Avatar
Thanks for your effort posting all this info. Your first thread was a great resource for me, Im doing the install on my 2.2 HHR right now, but I keep getting hung up on things. Right now, I cant manage to get the LSJ idler on. How the heck do you get the pulley, bolt, and your fingers in there? I found the cutout into the frame rail, but with the engine mount bracket on top there seems no way to manage it. Any helpful tips on that?
Old 07-21-2013 | 12:39 AM
  #58
SlowBalt_06's Avatar
your an auto the motor is clocked forward abit more? long extenion and a swivel socket should do ya
Old 07-21-2013 | 01:18 AM
  #59
Beck's Avatar
What he said. Try a wobble extension or a swivel socket. i also removed alternator to easier remove and install the idler assembly.
Old 07-21-2013 | 05:55 PM
  #60
davev9150's Avatar
Ok found out the hole in the frame goes all the way through to the wheel well, that should let me get the bolt in the idler.
Old 07-22-2013 | 09:17 AM
  #61
Tjolley's Avatar
And the ethan torque wrench
Old 07-22-2013 | 09:37 AM
  #62
Tjolley's Avatar
Old 07-22-2013 | 08:44 PM
  #63
look at the newb with the double post
Old 07-27-2013 | 09:27 PM
  #64
Beck's Avatar
burned out all the bad gas and got a fresh tank in there. Tuned the car today and she's running great. Gonna watch this tune for a bit and the E85 switch will be coming soon.
Old 07-28-2013 | 09:13 AM
  #65
Tjolley's Avatar
Hell ya
Old 07-28-2013 | 10:25 AM
  #66
Tjolley's Avatar
Car runs good with a relatively mild tune.
11.2 wot afr
Old 07-28-2013 | 10:28 AM
  #67
noorj's Avatar
gas or e? how much timing you gettin?
Old 07-28-2013 | 10:40 AM
  #68
Tjolley's Avatar
Its on gas right now
13° with a 140° charge temp.
Thats on a 2.8 pulley
Old 07-28-2013 | 12:56 PM
  #69
noorj's Avatar
damn thats some hot air
Old 07-28-2013 | 01:26 PM
  #70
Tjolley's Avatar
Not to bad for a zzps3 he
Old 08-18-2013 | 03:17 AM
  #71
Jacob4ta's Avatar
Pat and I just swapped parts. He's going stock and im SCd now! Pats a really good guy and knowledgeable. He does recommend a new tune though to really bring out potential.
Old 10-20-2013 | 06:20 AM
  #72
Beck's Avatar
Update time.
Found out intercooler pump was going bad. Replaced pump and drastically cut intake temps.
Made the conversion to e85 and car feels great with advancements made to the timing, but still working out some issues with getting the 80lb fuel injectors to idle properly.
Did some hard pulls and car flies to 100. Will get a dyno day setup hopefully sometime before the end of the year once I have the tune dialed in.
Old 10-20-2013 | 09:12 AM
  #73
noorj's Avatar
stock fuel system? I have the siemens/mototron 80's zzp sells and my idle is deadnuts perfect. PM me if you want me to send you the settings.
sounds like a real fun setup tho man, gotta love that ethanol how much whp you lookin for?
Old 10-20-2013 | 01:58 PM
  #74
Chaos_Six's Avatar
Hey Beck, I know you have 9000 times the experience with SCing the 2.4 but I do have some input. For your intercooler pump use one from a mustang SVT. they are brushless unlike the bosch, which is why they fail so often.
cxracing.com: Intercooler SuperCharger water Coolant Pump SVT Mustang
Old 10-20-2013 | 02:40 PM
  #75
Beck's Avatar
Yup, Stock fuel system, zzp 80's, but im running an LS4 tb, not sure if its adding to our problem here. I'd love to compare your settings to mine and see if maybe we're missing something. What RPM are you idling at?
The symptoms are strange mostly because the car will idle 100% fine sometimes, but the biggest issues im having is when im slowing down some times the car has trouble finding idle and will either stall on rare occasions or the idle with surge for a few seconds before it catches idle. We set our idle RPM a little higher (around 900rpm) and it helped a little bit but still not 100%
good to know for future replacement when necessary.
Quick Reply: Beck's Latest Supercharged 2.4 Build
