Blew my intake manifold on the dyno today, cant make more than 11 psi
yeah, my gauge wont read any boost at all now even though i can hear the turbo spooling and blowing off but i try to stay off boost. When acceling the vacuum level just increases instead of going to 0 like normal.
ARE YOU RETARDED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
golden rule #3 of having a turbo car, if **** on the outlet side of the compressor has major leaks, blows apart, ect YOU STOP DRIVING THE GOD DAM CAR.
i hope you like paying for a turbo rebuild, your on the fast track to needing one.
run a compressor unloaded and shaft speed goes thru the ****** roof, POP goes the turbo.
man welds on plastic!!! hell must be freezing over!!
tats what i thought....
ok, i'm going to be as nice as i can here...
if its failing at the gasket, pull that bitch off and load up the grooves in the plastic flange with RTV. some red RTV would be 10X stronger than the lame little gasket on the manifold.
if its the intake manifold itself thats leaking, I've got two sitting around.. pm me.
Last edited by celicacobalt; 05-26-2008 at 08:50 AM. Reason: Automerged Doublepost
drive it as little as possible, it'll save you much time, money, and worry later.
Just don't cheap out, use ALOT, give it time to dry before you test.
so haw hard is it gonna be the remove the manifold and change the stuff out? Very time consuming? Just trying to see if its worth it to pay someone or if a novice like me would be able to safely pull it off.
very easy....just removing the manifold...a bunch of bolts and maybe the throttle body if its in the way of anything
#36
so i just get a new gasket and throw it on there? Any tq specs to follow? Any dmage indications i should be looking for incase its not the gasket? I wanna try just the gasket before i add the silicone stuff and see if this was a just freak failure that wont happen again under these power levels.
#37
dear god man, you MUST be a check book mechanic here...
all that work done on your car and you cant complete simple ****...
is it the gasket or the manifold?
you have said over and over again that the manifold popped...if thats true...why are you replacing the gasket?
if it was just the gasket...pop the manifold off by removing the few VARY visible bolts and studs, replace the gasket and tighten that bitch down.
your torque specs are....."grut tight"
simple.
simple.
#39
carb/choke cleaner has tons of ethyl in it, thus it evaporates wicked fast...so it "sucking in" is hard to believe to a point.
none the less, if your sure your not boost leaking via some where in the charge pipe(my bet) then pull the manifold....
if the gasket is intact....then you obviously have your answer as to what went bad.
#41
i had a shop look for a boost leak and all the testing came up clear. check BOV, all the charge piping, intercooler, fmu, turbo, exhaust manifold, maf sensor, and the intake manifold seemed fine at that point but then it started hissing at the end of the dyno session. musta been on the last 2 pulss cuz it was fine all day. Yeah we sprayed the injectors because that was the 1st thing we thought since i had just installed the 60's but the choke cleaner just puddled up around the injectors but when sprayed on the manifold at the connecting point to the head it sucked right down into the crevice.
So this is a one piece gasket that i can get from the dealer for a couple bucks right? i saw it online for $3 something so i hope the dealer doesnt charge too much more for the part. I wanna try to install the new gasket tomorrow if i can get the part.
#44
sorry.. ^^^ brain lag.
i really think your best bet is alot of RTV... now that you see what your dealing with, load up all those grooves with it and sit it back on..
(in otherwords, it never works like this: 19psig is fine. 19.9 psig is okay. but your flloorboards fall out at 20psig)
#46
thanks for the help. i ordered the new stock gasket and im gonna attempt to install it this afternoon and see if the problem is solved or if i have bigger issues.
Is that picture above a pic of the lsj manifold? I just wanna make sure cuz i only ordered 1 gasket and that pic is 4 seperate gaskets.
#47
a couple 10mm bolts and 2 10mm nuts. very easy. just mark or memorize your wire hookups..
wont help... the 2.4 manifold flange is not solid like the lsj, in fact adding the lsj's gasket would introduce more failure points.
your pushing the manifold far beyond what its designed to do, failure is never a boolean operation.
(fail buzzer rings)
the flange is quite solid, as one can see the molded cross-hatch reinforcement.
the bolt pattern across the car's is identical, and with both the 2.4 and LSJ manifold being a solid piece (we not dealing with a flexible material in any case) the MLS gasket will hold up superior to any organic or fabric gasket you may have in mind.
RTV would be a worst case idea at best.
i have much experience with cars that run the 2.4L eco. Boosted, NA, N20, ect...the manifold holds just peachy well past 11-12psi. if the gasket goes, jump to an MLS piece....same process as you do when replacing / upgrading head gaskets.
when tightened down the manifold would put fairly even pressure across the gasket, thus sealing it and holding things together quite nice.
the rubber seals that are internal to the manifold will only aid the situation.
this manifold is made of the same material and design as the SIDI engines that come boosted out of the factory at 18-21psi.
#48
so if i go to the parts dept. and ask for the LSJ intake manifold gasket, that will fit right on mine with no problem? I wanna go pick up the part by 2pm today and i have them holding my LE5 gasket now.
just spoke with the dealer and they say there should be no way the LSJ and LE5 gaskets could be interchanged.
Last edited by celicacobalt; 05-27-2008 at 11:50 AM. Reason: Automerged Doublepost
#50
They mentioned the bolt pattern being different actually because they went and got a 2.4 manifold off the shelf and layed the lsj gasket on it and said it wouldnt bolt up right. I need to buy the 4 seperate le5 gaskets they said. the 1 piece lsj gasket wont work.
