Blew my intake manifold on the dyno today, cant make more than 11 psi
Old 05-27-2008 | 03:48 PM
  #51
bigworm's Avatar
Originally Posted by 06black
(fail buzzer rings)
the flange is quite solid, as one can see the molded cross-hatch reinforcement.
[insert trendy, witless catch-phrase here]
cross-hatch reinforcement != solid; theres no argument here. the sky is blue. If you'd like i can post a pic of the LSJ manifold flange tonight, even show you the LSJ gasket on the LE5 manifold if you'd like, it's a bad idea. yes same bolt pattern - no question there, but the LSJ manifold is a solid flat piece designed to crush and hold a normal gasket. With the LE5 and the additional gasket your contact with the LSJ gasket would be minimal, and even worse this does NOTHING to solve the issue with the LE5 gasket failing.
The purpose of a gasket is to fail before you create other mechanical failures. How then will adding more points of failure to an already flaky gasket help improve sealing?
What is the purpose of RTV? To create a seal.
the rubber seals that are internal to the manifold will only aid the situation.
those are exactly whats failing it appears...
this manifold is made of the same material and design as the SIDI engines that come boosted out of the factory at 18-21psi.
which engine? the LNF (SIDI 2.0L) uses a aluminum intake, the saab is aluminum... even the LY7 is aluminum... regardless, failure is never a boolean operation.
Old 05-27-2008 | 08:57 PM
  #52
celicacobalt's Avatar
Ok, changed out the gaskets today after work. The stock gaskets were green with little bumps on the edges. the new ones i got from the dealer were orange and totally solid around the edges. The new ones look alot stronger. Manifold has stopped leaking now with new gaskets.
Next issue, Injector #2 is leaking vacuum and I cant get it to stay in hard enough to stop it. Pulled the fuel rail and injectors and everything looks normal.
My tuner said that he remembers pulling apart an ecotec and seeing some kind of internal O ring seated in the head on bank #2 where the injector plugs into. He says that could be the issue. Im taking it to him in the morning since i dont know what else to do. I was starting to think that i could pick up a fatter O ring that fits on the end of the injector but i dont know for sure if thats the issue.
Old 05-27-2008 | 09:05 PM
  #53
Red2.4SS's Avatar
buwhahaha.
14psi on a 30lb/min a compressor.....and you think you'll hit 300.
not a chance in hell.
heres how the numbers line up thus far.
your at a PR of about ~1.5 (a bit less then)
that PR at a MAX flow on a 28RS is about 30lb/min (428CFM) that airflow supports about 285hp.
factor in you smaller boost numbers and drive train loss, and your left with your 250ish mark.
time to open your eyes if you want 300.
as for your intake manifold, did it blow or was it the gasket?
the manifold its self has been tested, validated, and used at MUCH higher boost numbers.
I have more power than that with this turbo @ 10psi!
area all your injector o rings properly seated? are the fuel rail clips in place to hold the injector where it belongs?
Old 05-27-2008 | 09:09 PM
  #54
yeah the O rings are seated fine, the clips are on good. the only thing i can see is that injector #2 is slightly tilted at an angle as compared to the other 3 which are all at the same angle when seated. I took them out and tried to align the 2nd one but it just sits right back in at a slight tilt. Like the fuel rail is forcing it to sit that way.
Old 05-27-2008 | 09:30 PM
  #55
alleycat58's Avatar
If your tuner saw ANYTHING on "bank #2" on a Cobalt I think you've found your first issue....double vision.
Old 05-27-2008 | 10:05 PM
  #56
bigworm's Avatar
this might sound hella gay.. but vasoline on the o-rings helps... both on the injector o-rings and the little cup thing they sit in.
Old 05-27-2008 | 10:13 PM
  #57
BennyHHR's Avatar
Despite your sexual orientation, bigworm....
That is actually what GM recommends in their build books!!
Old 05-27-2008 | 10:48 PM
  #58
bigworm's Avatar
oh well, there you go... just thought it was an old trick for people that arnt afraid to use a little extra RTV on their cars.
Old 05-28-2008 | 12:14 PM
  #59
Turbo06Sedan's Avatar
Bill has told me that at 14psi, accompanied with 90psi of the on boost fuel psi, should net approx 290whp.
I know the plastic intake manifolds are designed to fail at approx. 15psi.
Old 05-28-2008 | 12:19 PM
  #60
lsjwannabe's Avatar
i see injectors failing
Old 05-28-2008 | 07:26 PM
  #61
Got the issue fixed now. no more manifold leak and no more injector leak. Problem was a broken O ring that sits in the adapter in the head. so the O ring on the injectors were fine but i wasnt aware that there was an additional O ring in the head. So now i just gotta get my tuning finsihed next week.
I think my boost psi is being limited by my 2.5 inch exhaust, thats the only other thing i can think of as to why im only getting 11 psi with the wastegate actuator fully turned to capacity.
GaryGibblez
01-14-2020 10:35 AM
SmitBag
09-07-2016 08:05 AM
Spanky's Monkey
03-07-2016 06:06 PM
TheSandMan
09-20-2015 06:02 AM
Josh@ottp
09-17-2015 12:03 PM
Quick Reply: Blew my intake manifold on the dyno today, cant make more than 11 psi
