boost leak? 2.4/sc
boost leak? 2.4/sc
just wondering if i'm on a 3." pulley which is supposed to put me at 10psi which it has been pushing and now all of a sudden im pushing 5psi or 2.5psi and my WOT AFR went from 11.7-11.8 (10psi) down to 11.0(2.5-5psi) would this be a boost leak? the car runs perfectly fine otherwise but is more sluggish then usual obviously since im only pushing half the psi.
ya i have dual pass and it is not fixed, i fixed a slipping belt which i though was the cause but just drove it to class and now im pushing maybe 1 psi. and still running 10.9-11.0 rich at WOT.
i also have a CEL now for a P0121 code which is for the TPS. the TPS is on the TB correct? if it is this could be my problem, possibly a bad connection because i had to solder the new sensor on.
lesson of the day: don't cap the bottom excerpt on the little canister thing thats attached to the side of the SC thats ment to work as a boost controller. it'll control the boost alright.
WOW....
WOW....
it;s the silver cylinder looking thing attached to the SC on the engine side down towards the TB. it should have a hose connecting it to the SC and then another nipple excerpt below it LEAVE IT UNCAPPED it's for a boost controller.
what pulley you on, 2.8?
yes, i can now spin my tires through all of first and some of second lol. and it actually goes.
Atleast you found the problem man. Now lets see some vids of your beast lol
and i have one more surprise i will be doing sometime later this month or possibly next month that will; as long as everything goes well, leave everyone like WTF lol.
n20saturn
09-30-2015 12:26 AM
