Boosted 2.4 which clutch should i get?
Old 12-22-2011 | 02:03 PM
Brags's Avatar
I also agree with getting the adj clutch rod. My exedy was on the floor before I got it.
Old 12-23-2011 | 08:06 AM
DCOBALTSS's Avatar
For the adjustable clutch rod is there anything else to change or just this
is there a howto somewhere?
thanks
Old 12-23-2011 | 09:53 AM
Verbatim's Avatar
I would suggest the SPEC 3+. I drive my car every day to work and back and once a month when I go to school I spend about an hour in traffic on the interstate doing between 0-15mph.
The pedal is in the stock location( for me anyways) and it holds; I dont dump the clutch or anything but I am pretty rough on it a couple times a week. I have had it for prolly around 10-15K miles and it should hold the TVS just fine when it gets installed in March
Just remembered...This is a blurry-ass picture, but it is the best I have. sorry
This is the only reason that I get some chatter if I dont hit it perfectly. I was running out of time and my boss needed my bay and I didnt have the time to take the flywheel to a machine shop. I went ahead and chucked it onto our brake lathe and used a die grinder with 23 grit and just let her eat.
Old 12-23-2011 | 10:12 AM
hhrfreek's Avatar
Originally Posted by Zdeuce4
exedy stg 2 cost me 340 shipped from a vendor off of here. zzp = 600+...........
the exedy is also good to around 350 whp. they advertise less but when you speak to them they tell you theres like a 30% buffer i think it was.. that it would cover higher than the advertised amount.
The ZZP kit comes with a flywheel though. If you got the Exedy clutch/flywheel you'd be looking at least $650 which is on par with ZZP stage 1... and they probably have around the same capacity. The ZZP kit is competitively priced.
I agree with everyone about the Exedy stage 2. It has great holding power and is reasonably priced. The adj clutch rod would be nice though with the Exedy clutch. If you are considering a flywheel as well though I would look into the ZZP kit too, otherwise Exedy is the way to go.
Last year I ordered a Exedy flywheel and clutch and Exedy screwed up manufacturing by labeling the flywheels wrong. They accidentally produced a batch of flywheels and labeled them GF501, but they were actually for a Honda iirc. Then I tried to order a GF501 and they didn't have any, they had a bunch of Honda flywheels though . So the lead time was about 3 weeks to get one out, but I could not wait that long since my car was already apart so I just had the stocker machined and reinstalled it. Since I am dropping my sub frame again I decided to get a light flywheel and a clutch that will hopefully be closer to stock pedal pressure.
Mine disengages really low too, but works ok with the stock rod.
Old 12-23-2011 | 11:47 AM
Brags's Avatar
When I ran the exedy I also used their light flywheel. Huge diff in revs, really quick. But mine was louder than my exhaust lol
Old 12-24-2011 | 03:07 PM
Zdeuce4's Avatar
i ordered a factory flywheel, slave, and bolts for about another 150.. still came out pretty good.
Old 12-25-2011 | 11:32 AM
mmcgee123's Avatar
I have a Spec stage 3 6 puck going on 40k on it at 350+ ftlbs of torque works perfect
Old 01-01-2012 | 06:51 PM
DCOBALTSS's Avatar
So i see a lot of people goes with Exedy stage 2 + adjustable rod from zzp
from where can i order the Exedy stage 2 for a decent price.
thanks and happy new year guys!!
Old 01-01-2012 | 07:00 PM
DCOBALTSS's Avatar
Do i need a new flywheel? (im really a noob here sorry)
Old 01-01-2012 | 07:06 PM
TurboTechRacing's Avatar
We have the exedy and spec brands on www.TurboTechRacing.com
Old 01-01-2012 | 07:21 PM
  #36
DCOBALTSS's Avatar
what else do i need when changing my clutch?
thanks
Old 01-01-2012 | 08:33 PM
  #37
hhrfreek's Avatar
You should get your flywheel resurfaced. Flywheel bolts are tty. Bolts are around $35 bucks for a set...if you get ARP bolts they are a little less.
Also check your throw out bearing. If it is not buttery smooth then replace it. There is a boot on it as well check it for cracking or tears...somehow mine has a hole in it. I just picked one up through the local GM dealer for about $115.
Old 01-02-2012 | 12:56 PM
  #38
DCOBALTSS's Avatar
ok thanks
Old 01-02-2012 | 01:11 PM
  #39
DCOBALTSS's Avatar
if i get the zzp one stage 2
Includes:
Fidanza lightweight flywheel
Larger 9.5" disc
Increased clamp load pressure plate
Stage 2 comes with a full face Kevlar disc.
Whats the rating for stage 2? Did you get stage 2
Old 01-02-2012 | 08:14 PM
  #40
Zdeuce4's Avatar
I got mine from ngamotorsports for 340 shipped.
Old 01-04-2012 | 02:20 AM
  #41
Calae's Avatar
Originally Posted by DCOBALTSS
Cool thanks guys for the opinions if other people have any concerns about the zzp one it would be great to know
I just installed the ZZP stage 2 kit in my 2.4 (not boosted yet) and I love it. Only a day driving on it and it feels way better than stock. No slippage at all and it has very little pedal resistance which was important to me as I DD my car. No pics unfortunately though.
Old 01-04-2012 | 07:48 AM
  #42
hhrfreek's Avatar
Includes:
Larger 9.5" disc
I asked about the rating and told ZZP what my plans were for my build and Tim said hes sure the stage 2 will be fine. I ordered one and they come into stock today actually so it should be here soon.
My guess is anyone doing SC builds the Stage 2 is fine.
They don't have ratings for the 2.4l kits, but if you look at the design is sounds like the F35 (9.5") surface. They do have ratings for their SS clutches and the SS Stage 2 1200# plate with kevlar is good to 300ftlbs. The stage 2 2.4l kevlar has a 1500# plate...so I would guess it'd be good for much more than 300ftlbs...though it'd be nice if ZZP listed the ratings.
Old 01-04-2012 | 10:30 AM
  #43
DCOBALTSS's Avatar
Did you order the adjustable rod too??
I think im gonna go with zzp since we get a complete kit with it and its reliable too.
Old 01-04-2012 | 10:02 PM
  #44
hhrfreek's Avatar
No. I just ordered the clutch. I figured that this was going to be easier than the exedy so I didn't bother. I will have it tomorrow and I'll upload some pics.
Old 01-04-2012 | 10:20 PM
  #45
DCOBALTSS's Avatar
ok cool
Old 01-05-2012 | 10:43 PM
  #46
hhrfreek's Avatar
This kit weighs about 10lbs less than the stock flywheel/exedy combo(30 vs 20lbs, didn't have a digit scale handy) Also the friction surface diameter is 242 vs 230mm so it is a 1/2" larger. Can't wait to feel the lighter set up
Old 01-06-2012 | 08:57 AM
  #47
stenguyen1's Avatar
yea when your doing your clutch make sure you replace the throw out bearing. its better to replace it now than later. and try thmotorsports.com for the clutch. that where i got mine.
Old 01-06-2012 | 09:12 AM
  #48
hhrfreek's Avatar
Thats where I got my Exedy clutch. They have good prices and great customer service as well.
Just picked up a throw out bearing at GM for $115 and got some ARP flywheel bolts from ZZP for $26.
Old 01-06-2012 | 09:52 AM
  #49
DCOBALTSS's Avatar
Whats the part number for the throw out bearing?
Old 01-06-2012 | 08:33 PM
  #50
hhrfreek's Avatar
Not sure...I can let you know tomorrow, my car is at work.
Quick Reply: Boosted 2.4 which clutch should i get?
