Boosted 2.4 which clutch should i get?
Old 01-07-2012 | 02:53 PM
  #51
hhrfreek's Avatar
Yo! Part number for the throw out bearing is 12582666.
Old 01-07-2012 | 03:23 PM
  #52
-TurboSS-'s Avatar
I'm guessing I'll have to go larger then the ZZP Stage 2 for my TVS build. I'm going to pick up the Quafie LSD also.
Old 01-07-2012 | 03:47 PM
  #53
hhrfreek's Avatar
I would inquire with ZZP on that one. I just want to be around 300wtq.
LSD = I put one in last winter. It sucks when you can only get traction going perfectly straight.
Old 01-07-2012 | 06:03 PM
  #54
DCOBALTSS's Avatar
cool thanks man
Old 01-08-2012 | 07:21 AM
  #55
-TurboSS-'s Avatar
Yeah, me and Tim are debating meth right now. I would like to get it since 91 is the only premium widely available, which in town I can get 94. I'm trying to keep the budget reasonable but it is very hard once you start. lol. I might just axe the meth kit and tone down the goals a little.
Old 01-08-2012 | 12:01 PM
  #56
Brags's Avatar
I'm pretty sure the zzp clutches for 2.2/2.4 is just the lsj stage clutch with a lsj fidanza flywheel with bolt holes for f23. This is why the surface area is larger. Not a bad thing just explaining why it surface area is larger
Old 01-08-2012 | 04:40 PM
  #57
hhrfreek's Avatar
I know I was just confirming it. They sort of elude to that on their webiste. Then they must just have the clutch disc made for our F23 input shaft. I am only a few days away from breaking it in. Damn can't wait!
Old 01-13-2012 | 08:49 AM
  #58
hhrfreek's Avatar
Just installed my ZZP 2.4l clutch kit. Didn't get much driving on it since it was snowing last night, but it feels way better than the exedy clutch. I am not kidding I bet it is a 1/3 of the pedal pressure. I am thrilled I have my stock feeling clutch back and one that is going to hold a lot of power as well.
Old 01-13-2012 | 11:23 PM
  #59
IonNinja's Avatar
i wonder if the ZZP stage 1 clutch would be sufficient for an m62 build
Old 01-14-2012 | 06:33 AM
  #60
hhrfreek's Avatar
Most likely. Most m62 builds end up being ~225whp and the stock clutch is good to ~225whp. Mine started slipping when I put on a 3.1" iirc and I was probably around 230whp
Old 01-14-2012 | 08:19 AM
  #61
TurboTechRacing's Avatar
Check out the new KY clutch kits we carry, better in price than the other guys, and KY uses a better pressure plate.
They use to use Sachs (same one South Bend uses), but they didnt hold the required pressure, so they now use a better pressure plate.
These KY kits are truely a great product.
Old 01-14-2012 | 08:37 AM
  #62
hhrfreek's Avatar
Kewl. Thanks for pointing that out. Sounds like another good option.
FYI for everyone else. South Bend makes the clutch kit for ZZP and they use a Sachs pressure plate.
Though couldn't they have just used a higher pressure plate from Sachs? Who makes their pressure plate now? Doesn't it seem like the larger friction surface from the LSJ/LNF is a great upgrade for the 2.4l? Should allow you higher holding power and lower pedal pressure. The Exedy pedal pressure is terribly hard compared to the ZZP I just put in. JW. Thanks
Old 01-14-2012 | 09:05 AM
  #63
CC3 will chime in I am sure, he has more details.
Old 01-14-2012 | 08:05 PM
  #64
DCOBALTSS's Avatar
definitely getting zzp clutch
05-28-2022 03:47 AM
Zharrington_2010LNF
02-08-2016 01:43 PM
RaginChopsuey
10-27-2015 01:27 PM
patooyee
10-15-2015 05:11 PM
SSLOW06
10-01-2015 07:21 PM
Quick Reply: Boosted 2.4 which clutch should i get?
