CA header problem
CA header problem
ok i just bought a CA header. i tried installing it the other day everything was going fine untill i tried to tighten the bolts back up. the header would push on the coolant bypass pipe and would cause it to leak. did anyone else have this problem? what did you do to fix it? thanks
What year and model cobalt you got? What version header did you purchase?
nevermind, checked your profile. It be either the version of the header or may be like brandon said you gotta twist the coolant pipe.
z28addiction
09-28-2015 12:03 AM
