Chaos Six SC Build!
Old 09-05-2013 | 07:04 PM
  #76
Chaos_Six's Avatar
I have a extra boost gauge... :O lol
How much you want for it? :P
Old 09-05-2013 | 07:06 PM
  #77
Chaos_Six's Avatar
Originally Posted by 574
Why did you say the car wouldn't see the road until spring '14? If I were you I would have just gathered everything I needed and did the swap in a weekend.
That's what my intentions were, I was going to pull the motor and build it. I changed my mind, just gonna get this sc build done and buy another motor and build it for turbo.
Old 09-05-2013 | 07:10 PM
  #78
Twoozofjuice's Avatar
20+ ship. Pm me
Old 09-05-2013 | 11:17 PM
  #79
Chaos_Six's Avatar
20+ ship. Pm me
you has a PM
Old 09-06-2013 | 01:50 PM
  #80
Chaos_Six's Avatar
Bumper on, upper radiator hose on, intercooler pump on, some plumbing done(just waiting for option B to get here) intake manifold back on obviously...took washer fluid tank out to relocate maybe. probably won't even put it back in. good day today, for once!
Old 09-06-2013 | 03:24 PM
  #81
Jacob4ta's Avatar
Buy an lsj tank, bolts right up on the passenger side. Then run the wiring for the pump, and run the fluid lines across the engine bay. Fairly easy install too
Old 09-06-2013 | 03:29 PM
  #82
I was fine without running a tank but my dad kept telling me stuff about it and I didn't feel like paying $50 for alsj tank so what I did was clean out the stock airbox silencer drill a hole at the bottom plug up the rest od the holes and cut it up from the top so I had an opening to fill it. I assure you it looks terrible but it was just to make my dad happy lol.
Old 09-06-2013 | 11:25 PM
  #83
Chaos_Six's Avatar
Bahaha that's awesome! Idk if I'm gonna run it or not. I've owned the car since February this year and never used it once. When I took it out there wasn't even any moisture in it. Plus I should leave it out.
Half pound weight reduction.
Because racecar.
Old 09-08-2013 | 02:04 PM
  #84
Chaos_Six's Avatar
Derp
Installing Option B, obviously don't have a stock LSJ intercooler, just the stage 3 ZZP intercooler. For the air bleed line I can just drill and tap the fitting into an end tank, right?
Old 09-09-2013 | 05:19 PM
  #85
nhanson's Avatar
Yes...i did that with my GT500 HE.
Old 09-09-2013 | 08:51 PM
  #86
DarkChild's Avatar
I have a stock heat exchanger I could sell you. I could ship it out ASAP.
Old 09-09-2013 | 10:32 PM
  #87
silver_stig's Avatar
if youre running the stock LSJ heat exchanger, you will also need the LSJ radiator fan. The LSJ rad fan is NOT plug-n-play. you have to rewire your (1) stock plug to the (2) LSJ plugs. I found that out on my build.
Old 09-10-2013 | 02:57 AM
  #88
Chaos_Six's Avatar
Sounds like too much of a hassle for an intercooler. I'm just going to drill and tap mine.
Old 09-10-2013 | 03:05 AM
  #89
Jacob4ta's Avatar
Let me know how it all comes out. I too plan on running ZZPs stage 3 intercooler. Or even spend the extra cash on their stealth exchanger.
I installed ZZPs 3" intake and LSJ tb. Holy **** the whine!
Old 09-10-2013 | 12:15 PM
  #90
Chaos_Six's Avatar
I can't wait until mine is done! lol All I'm waiting in is that stupid 4 wire pigtail!
Old 09-10-2013 | 06:56 PM
  #91
DarkChild's Avatar
You can actually mount the heat exchanger in front of everything like the ZZP stealth exchanger. I bought the stealth exchanger and I like it a lot.
Old 09-11-2013 | 12:06 PM
  #92
Chaos_Six's Avatar
With the two heat exchangers does that provide better intercooling?
Old 09-11-2013 | 01:36 PM
  #93
For sure. I run the stock intercooler and a ZZP front mount. I never saw my temps go over 120 during a pull this summer. I set my car up to handle more boost than I currently run. I also have dual pass and option B.
Old 09-11-2013 | 01:41 PM
  #94
What size pulley are you on
Old 09-11-2013 | 03:53 PM
  #95
I'm running the stock pulley. i'm still very happy with it.
before I pulley down, I'd like to have tranny mounts and a new clutch ready.
But thats not happening until at least next year
Old 09-11-2013 | 04:34 PM
  #96
That explains the low temps...lol. I was like wtf I get to 140 in a pull...but its also 100+ here everyday so yeah that doesn't help
Old 09-11-2013 | 05:23 PM
  #97
nhanson's Avatar
Cant wait till i get 2.6 pulley...gotta fix this bitch first though
Old 09-11-2013 | 08:19 PM
  #98
DarkChild's Avatar
If you are interested throw me an offer. I have no need for it and would like for someone to be using it
Old 09-11-2013 | 11:08 PM
  #99
Chaos_Six's Avatar
I'd totally buy it if I didn't have my plumbing all done and everything put back on the car...
Old 09-22-2013 | 11:16 AM
  #100
Chaos_Six's Avatar
Car still not drivable. Waiting on either an idler or LSJ belt stuff... -___-
Quick Reply: Chaos Six SC Build!
