Chaos Six SC Build!
Old 09-22-2013 | 11:53 AM
  #101
Chaos_Six's Avatar
Anyone have the part number for the LSJ Idler?
Old 09-22-2013 | 07:17 PM
  #102
silver_stig's Avatar
GM Part # 12584364
Source: M62 S/c Parts list From LSJ to L61 motor. - Boost Forum - j-body.org - The J-Body Organization
Old 09-23-2013 | 12:39 AM
  #103
Chaos_Six's Avatar
Cool, thanks silver. For some reason I couldn't find it on GM parts direct.
Old 09-28-2013 | 11:56 PM
  #104
Chaos_Six's Avatar
IT RUNS AND DRIVES! Still runs a little weird. Drove it around but didn't dare to get on it. Don't have a boost gauge or wideband hooked up yet. Running ZZP canned tuned for now. Gonna park it and tuck my wires away until I get my gauges.
Old 09-29-2013 | 12:00 AM
  #105
andrewcarr1993's Avatar
VIDS are required.
Old 09-29-2013 | 07:15 PM
  #106
Chaos_Six's Avatar
No vids yet. Anyway, i'm throwing a code p0121. possibly bad throttle body..
Old 09-29-2013 | 08:58 PM
  #107
Jacob4ta's Avatar
I'm always throwing p0121 and p0106. Throttle position sensor and map sensor performance. I just ignore it because I haven't noticed anything weird while driving.
Old 09-29-2013 | 09:17 PM
  #108
Chaos_Six's Avatar
Unfortunately I'm pretty sure it's making the car bog down. When I drive it around it will bog down in 3rd and 4th, like it's lagging or something then finally kick in and jump up in RPM. Turning a corner I didn't have to stop, I downshifted to second to turn and in the turn I hit the gas a little bit and almost stalled out. I think the throttle body is messed up but I'm not sure. It's an LSJ TB. However it WAS from a junkyard. I'm going to put my LE5 one on tomorrow and see what happens.
Old 09-29-2013 | 09:25 PM
  #109
Chaos_Six's Avatar
Also had another code, I forget which one. It was a misfire on cylinder 2. Turns out I'm a retard and didn't gap my plugs. Gapped them, still had a misfire. Swapped coil packs from cylinder 2 and 4. Misfire is gone. (Thank you Noorj) :P
Currently not running a wideband OR a boost gauge...so the car is sitting there until they come in.
Old 09-29-2013 | 10:26 PM
  #110
Chaos_Six's Avatar
What is this port on the intake manifold? I have a feeling I forgot to plug it.
Old 09-29-2013 | 11:19 PM
  #111
nhanson's Avatar
That's for vacuum. I put my boost gauge line on there.
Old 09-30-2013 | 12:11 PM
  #112
Chaos_Six's Avatar
Okay, that's what I thought but I was just double checking. My boost gauge hasn't come in yet so I just plugged it with a rubber cap. I have a 3 gauge pod installed and no gauges! n:
Old 10-02-2013 | 11:40 PM
  #113
Chaos_Six's Avatar
durrr
Just got my LSJ belt stuff in as well as a Glowshift boost gauge. I can't find anything on the gauge install for a 2.4 SC. Can I run the one line from the nipple on the top of the intake manifold to the gauge?
Old 10-02-2013 | 11:45 PM
  #114
Twoozofjuice's Avatar
That's what I did ^
Old 10-02-2013 | 11:48 PM
  #115
Chaos_Six's Avatar
That's what I did ^
Yeah I realized I asked you on facebook a couple days ago right after I posted this lol
I'm just not sure where to get power from.
Old 10-02-2013 | 11:55 PM
  #116
Jacob4ta's Avatar
Just put the power wire to a fuse that's on the passenger side fuse box. Pick one that's powered when your key is turned to on. That's what I did. It's kind of janky but it works lol.
Old 10-03-2013 | 12:14 AM
  #117
Chaos_Six's Avatar
Okay! :P I guess that's tomorrows project before work.
Old 10-03-2013 | 07:44 AM
  #118
noorj's Avatar
the proper way!
add a fuse | eBay
Old 10-03-2013 | 10:15 AM
  #119
Chaos_Six's Avatar
Just bought 3 of them! Thanks noorj, didn't know they made anything like that.
Another dumb question though..
Do I need to drill a hole through the firewall to run the boost line?
Old 10-03-2013 | 10:27 AM
  #120
If you can't find a hole that works then yes. But look first there is most likely a spot you can get the hose through.
Old 10-03-2013 | 10:43 AM
  #121
noorj's Avatar
your 5 speed right? right by the clutch against the firewall inside the cabin there is a black rubber grommet that is 2 pieces, you pull the inner part out towards you. then you'll see the hole, push as much **** as you can fit thru there and put the inner grommet part back in. if you shove enough **** in there the inner part wont fit anymore so you'll have to trim the hole a little. it'll make more sense when you get under and look at it
Old 10-03-2013 | 11:58 PM
  #122
Chaos_Six's Avatar
Sounds interesting!
Still throwing an engine code with that throttle body. Won't be until Sunday now until I can install my idler and tensioner/boost gauge/and my old 2.4 TB. With my custom idler the belt chirps and slips, not sure if belt slip would coincide with the TB opening and closing..
Old 10-05-2013 | 11:02 PM
  #123
Chaos_Six's Avatar
Anyone know what size bolts are needed for the LSJ alternator bracket? I can't find anything about them
Old 10-06-2013 | 04:30 AM
  #124
LSJ Idler Pulley To Block
M10 X 1.50 x 75 (Qty 1)
LSJ Idler Pulley To Alternator Bracket
M8 x 1.25 x 25
LSJ Intake Manifold To Block
M6 x 1.0 X 75 (Qty 2)
LSJ Alternator Bracket To Block
M8 X 1.25 X 130 (Qty 3)
LSJ SC Bypass Valve To SC
M8 X 1.25 X 20 (Qty 2)
LSJ Tensioner Lower To Alternator Bracket
M8 x 1.25 x 35
LSJ Tensioner Upper To Alternator Bracket
M8 X 1.25 x 40… not standard bolt though. Has to be metric hex socket bolt.
Old 10-06-2013 | 11:19 AM
  #125
Chaos_Six's Avatar
M8 x 1.25 x 25
M8 x 1.25 x 35
Thanks! Now only if it would stop raining...
Quick Reply: Chaos Six SC Build!
