Chaos Six SC Build!
Old 11-07-2013 | 12:48 AM
  #151
IonNinja's Avatar
what does your AFR look like right before the misfire happens?
also if your clutch is slipping, your RPMs will quickly shoot up but you won't go anywhere...it'll be easy to tell if it happens
Old 11-07-2013 | 09:46 AM
  #152
noorj's Avatar
that sounds like a vac leak or bad tuning to me
like ionninja said revs will shoot up to redline as soon as the clutch slips and you wont go anywhere
Old 11-07-2013 | 11:20 AM
  #153
Chaos_Six's Avatar
Yup definitely need to put that clutch in. AFR is unknown still, have the wideband but still deciding on header/dp combo. I don't want to weld the bung in the stock one then have to get a new bung and weld it again. I'm lazy in that regard, plus not having the time lately to do much of anything. I'm gonna go get the codes now.
05-28-2022 03:47 AM
ineedacobaltss
11-07-2015 02:25 PM
hacadacalopolis
10-28-2015 06:09 PM
patooyee
10-15-2015 05:11 PM
09-26-2015 06:44 PM
Quick Reply: Chaos Six SC Build!
