Chicky's "Girl-Powered" 2.4 S/C'd Adventures
Old 01-16-2014, 04:38 PM
  #101
CobaltChicky88's Avatar
Originally Posted by silver_stig
If you want to run the stock heat exchanger, you will also need the LSJ rad fan. I know because that's what I had to do.
Ok buddy, you mentioned this and now I've obtained the parts needed to do this. Would you be able to shine any light on where I get started piecing this together?
Old 01-16-2014, 05:31 PM
  #102
bmxracerchamp12's Avatar
why i only ran a zzp s3. didnt want to hassle with cramming a stock h/e in.
Old 01-16-2014, 05:53 PM
  #103
I have one as purchased with most of my S/C kit so I intend to use it. Plus I imagine it'll help with fitment of all the LSJ parts I've obtained.
Old 01-17-2014, 10:59 PM
  #104
Dual pass, Option B, OTTP FMHE, and FE5 struts/shocks all on their way to my door. Times like these I wish I had more patience. lol
Old 01-17-2014, 11:04 PM
  #105
sandman's Avatar
Are you gonna use both the stock lsj heat exchanger and the ottp heat exchanger?
Old 01-17-2014, 11:08 PM
  #106
Yes. Not really sure where to start or how to even mount the LSJ fan onto the stock H/E. Hoping someone can shine some light.
Old 01-17-2014, 11:17 PM
  #107
sandman's Avatar
I don't know much about the lsj fans. Im curious as to why you are using two heat exchangers. Are you running the stock pulley?
Old 01-17-2014, 11:37 PM
  #108
I'll either be running 3.0 or 2.9 pulley, haven't really decided. It was recommended earlier in this thread by silver_stig for extra cooling.
Old 01-17-2014, 11:43 PM
  #109
Come to think of it, if it's that much of a hassle to "cram" the stock H/E in there then I might just skip this option. We'll see after I attempt it.
Old 01-17-2014, 11:47 PM
  #110
sandman's Avatar
My personal opinion is that you probably only need the one heat exchanger but if you do Install the both of them I'd start by taking your stock fan assembly out of there then slipping the heat exchanger and finding all of the bolt holes and then bolt it on and doing the same for the fan assembly then figure out the wiring.
Old 01-17-2014, 11:51 PM
  #111
The wiring is where I'm going to need help for sure. I'm going from one fan to two so I'm sure there's some complicated way of making that work. I'm sure there's someone on here who has done it before and hopefully I'll find a how-to somewheres.
Old 01-17-2014, 11:53 PM
  #112
sandman's Avatar
Getting a hold of silver stig is your best bet probably, I haven't heard of many setups like his
Old 01-17-2014, 11:55 PM
  #113
I'll have to PM him, don't think he has this thread sub'd.
Old 01-18-2014, 12:32 AM
  #114
thedubsack85's Avatar
Personally id just go with what someone who has built one's advice, Rather then second guess cause of comments from others... Just my .2 cents! Good luck!
Old 01-18-2014, 12:40 AM
  #115
silver_stig's Avatar
PM replied with detailed info. If the rest of you want to know, I can post it here as well.
Old 01-18-2014, 01:28 AM
  #116
Oh trust me when I say that I do extensive research on ANYthing I do to my car before I even attempt it. I'm a woman and a perfectionist. Things are done right the first time or not at all.
Old 01-18-2014, 02:04 AM
  #117
Verbatim's Avatar
you will be fine with the le5 rad setup
while you should be able to wire the fans in series, the main issue I see and would need to look into is that the rad fan in the le5(prolly other balts) is pulse width modulated...whether or not that would make a difference...
With just an OTTP HE, flow thru resevoir, dual pass, phenolic spacer; I see cruise IAT (post blower) of 20* above ambient( temperature on DIC) temps never changed between the 2.8 m62, 3.1 tvs, or 2.6 tvs
If you had the $, I would recommend the griffin HE and be done with it
Old 01-18-2014, 02:22 AM
  #118
ThexGovenor's Avatar
Griffen is good
Old 01-18-2014, 02:23 AM
  #119
silver_stig sent me a link to a pretty basic how-to regarding the wiring on the fans. It's actually quite simple.
https://www.cobaltss.net/forums/gene...16/index5.html
Old 01-18-2014, 10:10 AM
  #120
qwank's Avatar
just use to OTTP HE and skip the stock he, LSJ rad and fans, all that is a waste of money, The LE5 radiator and fan work really well. Stock fan system is a 2 speed, most of the time the low speed resistor rots out and leaves you with just high and that's where the problems happen. I would sell all the other crap and buy a new low speed resistor for $30 for piece of mind.
Old 01-18-2014, 12:41 PM
  #121
Gotta love going out and buying $200 or so worth of stuff and then having someone chime in with something like this. *rolls eyes* Anyone wanna back up these claims?
Old 01-18-2014, 01:35 PM
  #122
sandman's Avatar
I agree with him.
Old 01-18-2014, 05:15 PM
  #123
Powell Race Parts's Avatar
The fmic are junk cores with very poor cooling capability compared to the OEM aftercooler radiatior, but it makes your install easy. Easy is good. Search on here for posts by Zoomer@ZZP with pictures of cores, and experience of members with the fmic.
Old 01-19-2014, 12:16 AM
  #124
IonNinja's Avatar
All I run is a Cobra HE, dual pass and flow-through reservoir *shurgs*
Since you already have the other parts though might as well just install them, it's not going to hurt anything
Old 01-19-2014, 01:15 AM
  #125
Oh it's no worry really. The rad fan is brand new and will be taken back for refund come Monday, the stock H/E is for sale in the classifieds. Someone will need it eventually I'm sure. I'm a big fan of not making things harder than they need to be.
Quick Reply: Chicky's "Girl-Powered" 2.4 S/C'd Adventures
