Chicky's "Girl-Powered" 2.4 S/C'd Adventures
#126
One thing you may want to be aware of is that Option B was designed to work with the stock HE so if you don't have one, you'll need to tap your ottp HE so you can run the bleed line
#127
In the case of me not using the LSJ fan and h/e, I would still have the le5 stock h/e. Would this tapping issue still be the case? If so, I'll just end up using the LSJ one to save me the trouble. Just swap le5 for LSJ h/e, add ottp FMHE and done.
#131
Already ordered the ottp. Can't afford griffin. I don't know how to "tap" anything. I'll keep the stock H/E of that alleviates that problem. I just need to know what I'm doing. All this back n forth has me confused. Lol
#134
No I know. Honestly I wasn't trying to rely on anything but suggestions and instinct. I'm not dumb I'm just ultra cautious and kind of paranoid at times. I like to triple check things before I do them. Especially on my car. It's just hard to keep the info straight when I'm working on multiple elements of this build all at once. I appreciate you guys talking me through it though. I got it fingered now :-)
#135
Hahaha. No offense, but that last post made me chuckle! If your idea of doing good research is to start a thread and blindly follow peoples opinions, you're doing it wrong.
Research = FACTS
-look at people's builds
-look at dyno threads
-look in the forced induction section
-look in the 2.4L tech section
-use google to find specific info
Research = FACTS
#136
I spent about 3 months just understanding everything that would be required to SC my car. Once I had an idea on all of the combination of parts that could be used, plus their installation process, I felt comfortable not asking anymore questions, and spending the money for the parts.
#137
Research = FACTS
Research = FACTS
#138
#141
True story. It really is. The part that ends up being a task for me is the electrical mostly and anything involving power tools. Lol. I am a woman and I admit some things are just better left to the men to do. So I'll have to find someone who knows a thing or two that can hopefully do it for me.
#143
My supercharger build prep is going on 2 years now. LOL I started researching and buying parts when I had my Cavalier. The decided to get a G5GT when the 5th gear syncro went in the Cavalier. luckily I had 90% of my parts by this time, I just needed to get the G5 specific stuff.
by the way, is there a thread on tapping the front mount heat exchangers for option B?
#147
Why hasn't anyone suggested going with a flow thru reservoir?
-no need to weld/drill anything on your heat exchanger
feed underneath, the 2 hoses on top are the return from the dual pass
My opinion; I had absolutely no problems with my option B setup with the ottp heat exchanger, and I never ran that little bleeder hose from the reservoir to the HE...
#148
That little bleeder hose is key in getting any trapped air out of the stock H/E, since both ports are on the bottom any air going in sits on the top tank. A flow through tank will bleed any suspended air in the coolant while it sits in the tank but it still can't get air out of the H/E, and air in the H/E reduces it's effective cooling area/performance.
#149
