Clutch Help
Clutch Help
I've supercharged my 2.4 with a 3.1 pulley on a KY Stage 2 clutch. It slipped.
My current build is the same car and everything but turbo swapped on an S256ET @ 28psi on a KY Stage 3. That slipped too.
Has anyone tried the ZZP 9.5" Clutch kit for the 2.2/2.4? What other clutch will hold because I'm sick of these clutches slipping. I refuse to buy another KY Clutch. Thanks!
Either 1 drive better, or 2, do clutch masters. it's on zzp's website. Clutch Masters Stage Clutches - Transmission & Drivetrain
No I've been talking to a few people and the mods I had on each clutch, I've surpassed the capacity for both which is why they end up slipping. I'm probably going to go KY Stage 4 with a lightweight flywheel now and hope it holds. F23 has a smaller surface area than the F35 which is why they don't hold like the F35 clutches do. That's why I was so interested in the ZZP 2.4L 9.5" Clutch kit but it seems like no one has used it..
LsCobalt07 (02-02-2016)
Bandit2941
01-12-2017 08:06 AM
