Does the 2.4L have timing chain issues???
Old 03-20-2013 | 01:30 PM
apicia's Avatar
Originally Posted by Ceeker
the one very awesome thing about 2.4s, is that you can buy full motors for $400-$600 if you blow it, and trans for the same as well. I did my timing at 60k miles, but it was preventative rather than repair.
Did you replace it with OEM or upgraded?
Old 03-21-2013 | 07:57 PM
Ceeker's Avatar
my timing belt is OEM replacement. Did it the same day i put the ZZP turbo kit on. Out of paranoia/prevenative, and we had the whole motor ripped apart anyway.
As an update (as of today) i replaced my alternator (re-manufactured) and serpentine (OEM) @ 71k miles.
Alternator shorted (which was my fault) and serpentine was lightly weather cracked (damn cold canada!), but in no way ripped/teared. Again replaced the serpentine out of preventative maintenance ($30 belt) rather than failure
looking at the owners manual
http://www.gm.ca/media/owners/manual...nual_en_CA.pdf
CTRL+F search "6-2"
looks like the serp is good til 150k miles and no mention of timing belt replacement/failure
Old 03-21-2013 | 08:18 PM
lancethrustbone's Avatar
The timing chain is supposed to be set for lifetime of the car and need not ever be replaced. The tensioners and guides self adjust for slack over time. It is tensioner and guides you have to watch out for, being plastic (re: my post earlier).
Old 03-21-2013 | 08:48 PM
LS6Rally's Avatar
Still on my stock serp belt at 179K..... i have had a new one for over a year, just never took the time to install it.
Old 03-26-2013 | 09:58 PM
hitmanws6's Avatar
I was talking to a freind who has had a few 2.4's twist a cam lobe being these cams on these are hallow this does not surprise me ! also making the timing all crazy! interesting stuff .
GaryGibblez
01-14-2020 10:35 AM
bigdogstokes16
10-08-2015 10:28 PM
The Rookie24
09-20-2015 04:33 PM
medic710
09-06-2015 08:53 PM
Adam144
09-03-2015 07:48 PM
Quick Reply: Does the 2.4L have timing chain issues???
