Dyno #'s
Dyno #'s
Ok guys i finally dyno tuned my car and the numbers were 250 hp and 254 tq these numbers were of course corrected im in Colorado which is 5280ft above sea level. Well I have a question and I hope someone out there can help. our cars are said to handle 300 hp so with that said how much more can I push my car? Im I going of the corrected numbers or the other numbers cause it said I got 191hp and 195 tq. I hope you guys understand me im hell of tired but I just wanna know do I have more room as in 50hp or 110 hp to work with. Cause we are gonna put a meth kit and drop it to a 2.7 pulley so let me know what you guys think.
Oh and this was on a mustang dyno
sounds about right... you're trying to fill a 20% bigger motor with a baby blower and at huge altitude... If i had a 2.4 with a M62 i'd start with a 2.7 and probably end up with a 2.5 or something on it... you're just the victim of "big" cubes and huge altitude.. i know my SS/TC turns the boost up like 4.5lbs going from 790ft to 6300ft when i drive thru the mountains regularly...
See thats what I had in mind but I didnt know if my logic made sense haha. right now im at 7Psi with a 2.9 pulley and we are gonna experiment with the car we are gonna do 2.8 then 2.7 then just keep a close eye on it I just didnt understand.... if I had alot of room to work with.
I am in the same situation. I just dynoed my m62/2.4l and put down 257whp/233tq. I am not sure what I want to upgrade in this engine though. I am considering just pushing it to see what happens since there are numerous people that have gone well beyond 300whp. I am running a 3.1"(9psi) and am considering the same drop as you to about a 2.7". I am getting the ZZP 2.5" exhaust since I am still on the stock cat back tubing with a magnaflow muffler. I have a 2.9" pulley to throw on too. I am hoping the exhaust will relieve a bit of back pressure, lowering the boost for the pulley-down. When I get my exhaust I am heading back to the dyno. I am hoping the exhuast/pulley-down combo will yield another 30whp.
I am 5spd. These are my mods:
https://www.cobaltss.net/forums/dyno...4l-hhr-265971/
Why would a 2.9" and exhaust kill hp? I would think that would bring the hp up. Either the head or catback is causing a restriction for me. I am starting with the catback since it is quick. Porting the head in January.
What is LTH?
What is LTH?
haha noo an auto would kill hp, but its good you have the f23. a 2.9 coupled with exhaust will help a good amount. Ported head will help alot though, I would say you could even drop to a 2.7
well i am auto so im losing a lil there but some of the guys here in colorado have around the same mods and are LSJ and i rated a lil higher then them. so idk also my tq is a lil higher then the rest here
yeah the compression and extra displacement will help you there, but that tranny is definitely taking a good amount of power out. Think of getting a stall for it? that would help or any kind of build would free up some whp. but i definitely think E85 would give big gains if you have access to it. besides that if your looking for over 300 wheel i would say sell it all and go turbo.
Pretty good I logged until the laptop was low. I ended up leaning it out from .70(10.5) to .78(11.5) and added timing. I will lean it out a bit more to about .82 and add more timing. I ended up with about 18* at 7k rpms. Its making a difference that I can feel. Was having crazy idle issues and got that sorted out for the most part.
