engine disable
engine disable
i was drivin today and wasnt oayin attention cuz my music was to loud and i redlined second gear then went to put it in third and my car shut off and it said engine disabled engine power reduced i thinks the ecu shut off the engine and it wont turn on now its at the dealer anyone have this problem before????
i don't know why it won't start... but it should have just gone intom reduced engine power mode (limp mode) it should have stayed on, and it should have just had limited power. So i don't know what you did.
What does the car do when you turn the key?
it doesnt do anything i wont start it cranked a couple times i tried but wouldnt turn over it said engine disabled to so i think the ecu disabled the engine or somethin and needs reset by the dealer
I had it happen several times when I had a sensor unplugged it freaked out and went into power reduction mode. I unhooked the battery and reconnected and it worked fine again after.
o i just disconnected the power for a couple minutes and that didnt work i didnt kno u could touch them together but idk its at the dealer now so thy are gonna call me tomorrow and hopefully it wont cost anything for them to fix it but u really think that would work like legit?
Like I said I had a critical sensor unhooked so it freaked.
Once drained everything is reset!
The engine has a fuel shut off to prevent over revving.
I have personally missed a redline shift from 3-4 and went 3-2 and ran it up over 7500RPM and it survived!
wat kind of turbo u got and how much did it cost for everything
wow thats alot yo u kno of anything else i could do to my car wit out turboing it or super charging it ???
you could get the used supercharger and parts from an SS/SC they will bolt on then get a custom tune. That would be about half the cost for everything that you will need.
ya if ur pushing 264 at the wheels ull prob beat him my other friend got A SRT 4 stage 2 its pretty sick but the kid wit the s2k his bro got a 06 wrx and he is pushin 395 at the wheels and like 470 tq at the wheels that car is insane
