Engine Rattle on 2.4
Old 01-25-2013 | 10:48 PM
jerseypilot's Avatar
Hey all. I tried searching for engine rattle on the 2.4 but all results pointed to the TC/SCs. I was wondering if anyone had a clue as to why my 2.4 engines rattles when im in drive and idling. If i switch gears while idling, neutral for example, the rattle stops. It also stops when im in drive and I accelerate.
Is there anything that would cause this engine rattle only when Im in drive and idling?
Old 01-25-2013 | 11:20 PM
turbosmart4's Avatar
Hmmm vid or sound clip would help a lot.
Have u popped the hood to see where sound is coming from?
U might want to hear timing chain area.
Old 01-25-2013 | 11:26 PM
copson20's Avatar
Check the heat shield by the exhaust manifold.
Old 01-25-2013 | 11:40 PM
Ill try to take a video tomorrow and pinpoint the location, ill check the heatshield thanks.
But why would the heatshield only rattle in drive? and not neutral or park
Old 01-25-2013 | 11:43 PM
CordiaDOHC's Avatar
Maybe the throwout bearing?
Old 01-26-2013 | 12:09 AM
I have an A/T so I assume I dont have a throwout bearing, can an auto make a throwout bearing like rattle?
Old 01-26-2013 | 12:14 AM
buildmeanempire's Avatar
I've driven cars that did this and in fact my work truck does it also. Heat shield rattles in drive but no other time and would bet its your issue.
Old 01-26-2013 | 12:26 AM
tyler41390's Avatar
My car does the same thing
Old 01-26-2013 | 08:46 AM
CordiaDOHC's Avatar
Lol it shouldn't. Sorry the way you posted made me think manual.
Old 01-26-2013 | 10:06 PM
copson20's Avatar
Shield could be loose or bent or broken. With transmission in drive puts tension on engine causeing rattle.
Old 01-26-2013 | 11:12 PM
Buy a whole new engine and trans and call it a day.
Jk
Old 01-27-2013 | 11:08 AM
Mindrot's Avatar
x2
05-28-2022 03:47 AM
patooyee
10-15-2015 05:11 PM
jimbofug007
10-02-2015 12:06 PM
SSLOW06
10-01-2015 07:21 PM
patooyee
10-01-2015 01:07 PM
Quick Reply: Engine Rattle on 2.4
