Engine and Tranny
Old 07-24-2008 | 12:41 AM
ctg5040's Avatar
Engine and Tranny
Hey guys i'm totally new to this fourm. I just picked up a 06 2.4 5 speed, and i was thinking about going turbo with the hahn kit. My question is what will the stock engine hold power wise. I read 400 hp and read the 5 speed holds less than an auto. I know that the kit is made for a stock car but will it be reliable or should the engine also have some work done to it.
Also, i have a k&n intake, i read some people were having problem with the car idling high, what is the stock idle rpm. Thanks for the help.
Old 07-24-2008 | 03:24 AM
PenguinPIE's Avatar
i know the engine internals could handle quite a bit but forged pistons are recommended.
the 5 speed gearbox on the other hand doesnt hold up as much (its only rated 170tq if i remember correctly)
Old 07-24-2008 | 08:51 AM
nutsandboldts05's Avatar
Hahn and plenty of other guys have run 400-500WHP thru the stock parts on these cars. But since you are spending the money on a turbo kit for your car, go as far as getting a new flywheel and clutch and you should be fine.
Old 07-24-2008 | 10:48 AM
07GatorSS's Avatar
ctg you ever make it over to indiana?
Old 07-24-2008 | 03:26 PM
ctg5040's Avatar
Yea, i've been there a few times, its been a while tho.
Old 07-24-2008 | 05:33 PM
pjk91's Avatar
I've got 25,000 miles through my transmission/engine with about 85hp more than stock. Still going strong, and no rediculous slippage.
OrangeCoba
10-01-2015 10:00 PM
SSLOW06
10-01-2015 07:21 PM
patooyee
10-01-2015 01:07 PM
Iceberg
09-29-2015 12:33 PM
Iceberg
09-28-2015 01:31 PM
Quick Reply: Engine and Tranny
