Exhaust Options...
Old 04-07-2011 | 09:52 PM
Hammbones's Avatar
Exhaust Options...
I'm a little bit overwhelmed about some of the options available to upgrade my stock setup and I was curious if someone that has done quite a bit of exhaust research for the LE5 could talk to me on the phone or something. I'm about to purchase an aftermarket dp for cheap and I want to be sure I'm not going to run into any issues later on. PM me if you can help, Thanks!
Old 04-08-2011 | 11:31 AM
olivecj's Avatar
The zzp downpipe is fine, you should go with a custom exhaust if you wanna save money. If you wanna get something top notch i'd say go with the 2.5 inch corsa exhaust. turbo tech racing has a sale on right now for them. i hope this helps man.
Old 04-08-2011 | 11:33 AM
Zero6LS's Avatar
ive had a few dif exhausts on my 2.2 and i like the magnaflow alot. if u wanna save money tho get a custom one. it would prolly cost u $300 or so but its worth it
Old 04-08-2011 | 08:34 PM
Hammbones's Avatar
I did some shopping around today. I was able to find a guy that will install my DP, Custom Mendrel Bent Alluminized Steel and Stainless Steel Polished High Flow Muffler with a 15 inch 2.5 in diameter polished tip at the muffler exit...
But because the government thinks that docking my pay (Military) when I already make 60% less than Federal Minimum Wage I won't be able to get this until this ******* retarded crisis is abaited.
Old 04-10-2011 | 05:31 PM
TurboTechRacing's Avatar
Corsa is an great choice.
05-28-2022 03:47 AM
01-12-2016 12:01 AM
hacadacalopolis
10-28-2015 06:09 PM
patooyee
10-15-2015 05:11 PM
09-27-2015 08:53 PM
Quick Reply: Exhaust Options...
