exhaust system?
exhaust system?
once i found out that if i get a turbo for my cobalt it will have to run on high octane fuel im not getting a turbo so now im looking for an exhaust....
anybody got ne suggestions??
i got an 08 cobalt SPORT(not SS) with a 2.4L engine
Sorry to jack the thread, but are you not using 91 octane now? You are in Florida, and with that kind of heat, you are probably running into knock (ignition) retard if you are using a lower octane fuel. Do yourself a favour, and use 91 octane, before you spend (waste?) money on performance mods.
Lets see, $4k on a turbo setup for what, +100 hp? $600 on a catback for what, 10hp?
Waaay more gain per dollar with the turbo
Also by using a lower grade gas your actually getting less fuel economy because the ecu has to retard the timing in order to adjust for the lower octane fuel. As a result you get less hp and less fuel economy. I remember when i bought my g5 gt home from the dealership they filled it up with 87 octane fuel and the car was not running good at all and the gas lasted like a day and a half lol i knew they put shittty 87 in it. As soon as it was gone i filled my car back up with 91 octane and I immediatly felt a difference in acceleration and my fuel guage. So do yourself a favor and switch to 91 gas especially since your getting mods done to your car. And finally if you havent done it already switch over to synthetic oil that will make a difference with your engine running better as well and up your fuel economy a little more.
before you start modding, learn about your car. And seriously, like said, if maybe 2-5 dollars per week for higher octane is making you decide against spending thousands on a turbo, you shouldn't mod the car. If you use the recommended octane, you will get better gas mileage, which will offset the price difference.
