Exhaust is way too loud???
Im kinda nervous guys...i was driving this morning to work and it was fine ,,but when i went out later on to hang out and it was acting weird like the exhaust is super loud...performance is still there it still pulls hard in the higher rpms...too...and it crackles a little bit when i lef off the pedal and at idle is kinda normal..someone told me it miggt the cold air or something cause its really cold outside but any suggestions or opinions should i get this checkout????
definitely sounds like a leak to me. I would check all the connections from your header on back. Try to listen for any leaks or vibrations, one of the connections could just be loose. Cold air never made my old car's exhaust sound any louder. I had a header leak on my old car, a 95 accord, between the header and cat and until i fixed it by replacing the gasket it sounded like wet farts on leather every time i gased it
you don't need to take it to a shop if it's just a leak. You could fix that yourself easily just by getting under the car and checking the connections by either listening or placing your hand near any connections to feel any air leaking while the car is at idle. If it's loose just re-tighten, and if you need a new gasket just pick one up from the nearest auto parts shop, autozone etc. and install where needed. Who installed the exhaust for you?
yeah sounds like a leak but I have noticed a pretty big differance in starting in the cold, although, this is from Canadian winters.... -20C to -35C or colder starts.... I think the coldest I have ever started my car was at -47C or something like that.
yea i think i found out the problem it is an exhaust leak...the catalytic converter that connects to downpipe..i notice i went under and took a peepm theres a gap between where it bolts toghether.."its lose"...looks like a couple of bolts might have pop off
There used to be a place online where you could buy these like 3 piece interlocking exhaust flange covers for headers. I wanna say the place was hugeleys er sumpin similar. Any ways they work great to prevent exhaust leaks because the solid up the connection really well.
