exhuast
Old 09-08-2007 | 08:55 AM
yoppzilla's Avatar
exhuast
confused about the high flow catdownpipe and a cat back exhuast. Is best to have both(which I would think) or just a reg exhuast with a highflow cat or a reg downpipe with a cat back exhuast. Seems like to many cats lol, was not sure if they where going to benifit eachother or work against eachother if both had cats on them
Old 09-08-2007 | 09:00 AM
NJHK's Avatar
Note: You shouldn't buy a catalytic converter thinking it's really high flow, cause they aren't any different than your stock catalytic converter, that's why they are 50 state legal. The only reason to buy a so called "high flow cat" is to keep the same diameter as the rest of your exhaust system so it's not a bottleneck.
Old 09-08-2007 | 09:09 AM
D4u2s0t's Avatar
well, either way you'll only have 1 cat. and of course the lest restriction, the better the flow, which ='s more power. so you don't HAVE to do a downpipe/catback combo, but it would be better than just a downpipe or just a catback
Old 09-08-2007 | 09:31 AM
yoppzilla's Avatar
SO Your Saying THeirs A chance!!!!!
nah so basically according to what exhuast I would be getting would tell me what size or type of downpipe I would need, And if I was to get a exhuast on a stock downpipe their would be more retriction of air flow due to "bottleneck" on the pipe
Now I think I under stand it a lil better thanks fellas
Old 09-08-2007 | 09:33 AM
D4u2s0t's Avatar
yep. just make sure all your exhaust parts you buy are the same size. like don't get a 3" downpipe and a 2.5" catback.
Old 09-08-2007 | 09:41 AM
yoppzilla's Avatar
right because it would defeat the purpose of retricted air right
Old 09-08-2007 | 10:00 AM
Projekt's Avatar
Correct! + also whenever u get exhaust ur exhaust note will change..so look for what kinda sound you want I.E Magnaflow=Honda, SLP=Camaro :P
jmelton327
09-25-2015 09:44 AM
Jroy326
09-01-2015 07:37 PM
Switt23
02-13-2007 12:21 AM
bhowman1980
08-12-2006 12:42 PM
juststickit124
08-03-2006 12:33 AM
Quick Reply: exhuast
