External Wastegate/Timing Issue
Old 05-12-2012 | 04:04 PM
Mindrot's Avatar
Ill make this short and sweet. I have recently finished my build and I'm running on an external wastegate. I can slowly creep into boost without timing being pulled. But once the wastegate opens up it take out a LOT of timing. I can't do any solid pulls because the car falls on its ass. Everything is tight. Nothing is rubbing. I notice that timing is pulled first and nearly a second after I get KR. Thoughts? I know this is such a long shot.
Old 05-15-2012 | 09:36 AM
tomj77's Avatar
Did u tune for the New setup?
Old 05-15-2012 | 11:11 AM
Ch1ck3n's Avatar
Make sure your afrs are rich enough.
Old 05-15-2012 | 11:23 AM
ItalianJoe1's Avatar
How are your A/Fs through that transition?
Old 05-15-2012 | 11:33 AM
noorj's Avatar
On tip in you should be pretty rich then progressively get leaner, is your wideband showing that?
Could be some bad camshaft position sensors or cam actuators
Old 05-15-2012 | 01:10 PM
Mindrot's Avatar
Don't think someone would be dumb enough to do that.
Old 05-15-2012 | 01:12 PM
Mindrot's Avatar
I see a 12.5 under WOT. Tune isn't complete though yet. Just a base tune is what im working with atm. Ran into issues during my first day of tuning. Tune will be revised on Sunday since I have taken care of a few issues. If its not in the tune then im going to have to dig deeper
Old 05-26-2012 | 06:29 PM
stone4779's Avatar
Did you figure it out bro??
Old 05-26-2012 | 07:06 PM
Mindrot's Avatar
Yeah. Something was overlooked in the tune.
Trav3480
10-01-2015 08:17 PM
Tupp
09-30-2015 08:18 PM
yellow dragon
09-28-2015 09:49 PM
SlowSaturn
09-28-2015 11:03 AM
Quick Reply: External Wastegate/Timing Issue
