F-ing CEL
Old 05-07-2008 | 09:59 PM
Apcsox's Avatar
F-ing CEL
sooo, after my ex wrecked the Balt, it's had the CEL on..... codes p0440 and P0455....... EVAP leak small and EVAP leak large........ I had my mechanic smoke the engine, but he coudlnt find any leaks.... he said that when he researched it, one of the major causes after an accident and throwing those codes is due to the battery voltage getting messed up frm the car sitting and it tricks the computer into throwing those codes as an indication that the PCM nedds to be reflashed........ anybody have any ideas?
Old 05-07-2008 | 10:02 PM
XM15's Avatar
One of those could be from a loose gas cap IIRC.
Old 05-07-2008 | 10:15 PM
Apcsox's Avatar
hmmm, yea, it was swearing at me about the gas cap in the mesage center....... that may explain the "small leak".......... its the "large" that really concerns me
Old 05-08-2008 | 12:22 PM
Apcsox's Avatar
anybody else have ideas or run into this issue?
Old 05-08-2008 | 03:42 PM
Shaun927's Avatar
i came across an issue like this when i was working at ford and did the smoke test and its was comming out of the gas cap; and the big leak you have if you couldn't find it with a smoke machine u can try using a black light if nothing just get ur pcm reflashed your warranty should cover it
Old 05-08-2008 | 03:55 PM
rnjmur's Avatar
Have you cleared the codes and they keep coming back?
Old 05-08-2008 | 04:47 PM
bigworm's Avatar
was the accident to the front or rear of the car?
Old 05-09-2008 | 12:42 PM
Apcsox's Avatar
the rear..... got the smoke test dont, she crack the EVAP canister...... yeah insurance
turbochargedss2012
09-20-2023 12:17 PM
Cobalt08LS
06-19-2016 07:29 PM
Dustin24
47
02-12-2016 04:10 PM
DocSvensk
09-27-2015 02:24 PM
jcarroll53
09-24-2015 07:43 PM
Quick Reply: F-ing CEL
