A Few 2.4 Questions..
Old 08-05-2008 | 01:54 PM
averagewhiteboy's Avatar
Hey guys..
1. I have a 2.4 with the only go-fast mod being an Injen intake. I'm buying a GMPP exhaust off a local member within the month. The Performance one. How much HP/TQ did the Injen probably add, and then how much will the GMPP add onto that? I also have a few non-adding mods like the Shift Plus, and synthetic fluid to smoothen things out. Few more little things on the way.
2. After the GMPP, come spring, a tune may be a good idea since I won't be supercharging it for over a year. I'm auto so the tune will certainly yield benefits. how much does a tune usually cost for the usual requests? I wouldn't want to DYNO tune it until I go s/c, so this is for a non-dyno version..
3. After you s/c the 2.4, what'll your gas mileage drop to running a normal sized pulley and everything? Hell, if you have any idea on the stock pulley, then any "Stage" related numbers, feel free to let me in on those..
4. How much HP/TQ will a header + dp + high-flow-cat combo yeild you after the GMPP and Injen?
5. What kind of things can I have done to my car with the tune? Auto 2.4. '06 by the way, if that matters..
I figure that with the stock numbers being like 175, probably add 7 for the Injen, then 13 for the GMPP? Add 20 hp to get it to 195 crank (so then a solid probably 160 range wheel) should make it pretty reasonable. Then probably another 20 for the rest of the exhaust, maybe 15 for the tune - bringing it up to maybe 230 na, then add another 60 for the s/c in stock trim to 290.. Sound like that's a reasonable ballpark in any way?
I think that's all for now.. I'll post if I think of any more.. Thanks!
Old 08-05-2008 | 06:49 PM
pjk91's Avatar
Originally Posted by averagewhiteboy
Hey guys..
I get 22-24mph city, 28-30hwy
I have intake, zzp exhaust manifold and dp, stock exhaust, and intake. stock pulley. i'm putting down roughly 235whp/220tq.
Old 08-05-2008 | 07:39 PM
Red07SSNA's Avatar
Are you using the SS/SC cooling system and did you use the SS/SC PCM, or have your ECM tuned for the supercharger?
Old 08-06-2008 | 12:18 AM
REDFOCZ's Avatar
He had the stock ECM tuned for the boost.
Old 08-06-2008 | 07:26 PM
maverick0716's Avatar
Hey guys..
I would say your flywheel hp estimates are a bit high overall. With an intake, full exhaust (header, high flow cat, catback) and a tune, you'd be more around the 205-210 mark for flywheel hp.......or around 185 whp with a good tune.
Old 08-06-2008 | 07:31 PM
REDFOCZ's Avatar
sounds like my numbers
Old 08-07-2008 | 08:26 AM
celicacobalt's Avatar
i'd say with full bolt on's + tune, no supercharger you could get 175whp.
Old 08-07-2008 | 09:47 AM
Yeah.. The more I think about it the s/c just isn't really in the cards.. the suspension is gonna be like 800, tires, brakes, s/c front lip, clean trunk.. Too much.. Thanks for the info though!
Old 08-07-2008 | 07:38 PM
pjk91's Avatar
but all that stuff is not necessary in order to supercharge your 2.4. You need the parts (1500) and a tune (~300)
Old 08-08-2008 | 09:33 AM
I know.. But I need the brakes, and the suspension would be awesome. The s/c would certainly be cool, but I'm trying to move and ****.. Spending almost 2 grand isn't too logical at the present time..
Old 08-08-2008 | 10:22 AM
PpAzZ1101's Avatar
I think those estimates are a little high. I had an intake, downpipe, catback, and a tune and I still only put down about 160whp.
Believe it or not, these mods aren't really going to net you much as far as power. Now if you were to have some work done to the head, some cams, and then all of this crap, then you might see some decent gains.
Old 08-08-2008 | 11:18 AM
Yeah, I'm certainly not assuming that I'm gonna add an intake and beat Mustang GT's. lol. But more so than power, these mods really smooth things out. The response is better. So that's worth more in my book. At the end of the day, it's still a Cobalt. I don't need 400hp. lol. So I'm gonna do the rest of the stuff first, then after all is said and done, consider the s/c swap..
Would I benefit any from getting the entire LSJ motor, or just piece everything together?
Old 08-08-2008 | 11:53 AM
nitr0racing21's Avatar
I was wondering the same thing if I found a totaled SS w/LSJ and I throw the motor in a 2.4, but I think it may be better to buy heads and everything for the 2.4(I may buy a 2.4)
Old 08-08-2008 | 12:29 PM
I know the 2.4 is overall a way better motor, but I just figured it'd be easier to have the LSJ there so that everything that I'd need would be there..
Old 08-08-2008 | 12:35 PM
I wonder how much $$$$ its would take to build up the 2.4
Old 08-08-2008 | 12:51 PM
Depends. All motor or boost?
05-28-2022 03:47 AM
red9
10-04-2017 02:23 AM
Barkleyj605
10-24-2015 12:07 AM
patooyee
10-15-2015 05:11 PM
matthewwalsh1994@gma
09-10-2015 10:48 AM
Quick Reply: A Few 2.4 Questions..
