GMPP intake
#51
Originally Posted by LewiSS
Thanks! That pic is exactly what I needed! Now I know I will order one.
One idea I had this AM commuting to work is to use the gasket to mark the hood mat (vasoline works well ) and cut the mat just outside the gasket. Next step is to build a short - one inch or so - lip to attach to the hood to stick down to engage the gasket firmly. Thin aluminum c-channel extrusion might work, formed in the shape of the gasket/air box top and bonded to the hood. Finally, cut through the hood in the center of that, and place a hood scoop over the hole (with appropriate screen to keep from sucking in birds and small children ). I have some ideas for an aftermarket scoop that should match the styling of the hood (mostly the tapered ridge that sits almost over the airbox).
Don't know if that explaination makes sense, but it's clear in my head!
Oh, and the fact that the gasket doesn't actually seal well against the hood mat is probably why you're getting so much intake honk in the cabin. I don't know if having it seal well and breathing through the hood would help that or not.
Jay L.
Jay L.
Now if you could put in a flapper valve with a rubber gasket, or a sliding gate on the underside of the hood to seal it off in case of rain, you might have something. You could install an actuator cable under the dash, so if you hit a shower, just pull the lever.
The HSU would be to rig it with a solenoid and a moisture sensing switch that would handle the task automatically - cause you know, you might forget one time and then....
#52
Originally Posted by sushidog
Your idea sounds great, except for the first time it rains...
it wouldn't be as big of a deal as you think that it would... as long as you were not underwater, you could just shield the top (plumb) of the filter so that the rain wouldn't drop on it... it would just fall into the filter box and run out the bottom.
#53
Originally Posted by g5mike
GM does not condone intakes, they DON'T condone oiled filters,get a dryflow,I just spoke with a service guy and he confirmed this.There are several peaple on this page who work at dealerships,Im sure they can find this note from gm to the dealerships to look out for oiled filters,maybe some of these guys can elaberate on this, if I could find this memo I seen on the matrix forums, I would post it,good luck
#54
Originally Posted by hardtocope
How are you guarenteed better results.. the gm intake has to had some power, other wise if the tube in the fender was so restrictive they would of made a new one that goes with the intake.
because taking it off has less restrictions... a lot of the problem is the big ass bong under the car that the air has to travel through before getting up and into the engine... the intake was designed to be quiet, not the best performing... if it was designed with performance in mind, they wouldn't have come out with a GM intake, would they?
#55
The nice thing about the design is that the stock inlet would be the back-up - sealing the cold air inlet wouldn't starve the engine (any more than it is without the hood intake).
#56
I've been doing some more looking and it looks like I will build a thin, wide duct on the bottom of the hood to move air from a scoop in the middle of the hood to the air box seal. This is because the air box strattles the ridge on the hood, making placing a scoop directly over it impractical. Anyway, with the duct (which, BTW, is an old school GM approach) there would be room to place a flapper (again, another old school solution, but then they were vacuum operated).
#57
The ram air effect is difficult to achieve because the engine is trying to use almost 300cfm at WOT, max rpm while the scoop is trying to feed it. About 1 lb "boost" or positive manifold pressure will theoretically yield a 5% hp increase. To achieve this amount of manifold pressure typically takes a vehicle speed of well over 120mph, even with an "indy" size hood scoop.
The moral of the story: On a Cobalt, the ram-air effect would be totally useless in 1/4 mile drag. It would make some usable HP if you were trying for a top speed run though. For normal street applications, the cold air effect (increase in density) will be of much greater importance than the ram-air increase in density.
#58
Speaking of ram air, there's a reason the scoops on Pro Stock cars are so tall. You have to get that high to get out of the boundry layer of the hood and actually get good positive flow at speed. For the street, I prefer a much lower scoop.
I'll settle for a nice scoop (more for looks-ego than anything else) and outside air ducted from the scoop to the GMPP intake. I believe it will also quiet the intake honk at full throttle a bit, also (but that may be whishfull thinking).
We plan to get the intake ordered today. Will keep the board informed (with pics) as this evolves.
Dennis, if the duct design works out, I'll pass the template along to you for your installation if you want to do some fabricating.
-J-
#61
Originally Posted by roccobladr
whats the cheapest place that has this intake online? i just cant seem to find it.
Go to their main page, put the following number in the search field just under their logo:
17800653
#63
Too high/too big of a scoop causes too much drag and slows the car down, while too small of a scoop doesn't allow enough air in and hurts power that way. Pro stock guys, especially guys like WJ and Greg Anderson; do a lot of wind tunnel testing to optimize their hood scoops and bodies in general.
#64
$261 and it's not even a cold air intake..you can find a CIA online for $160 or even an injen wich is my best,.. was $230 and is a CIA. i've seen them before online and honestly it's the same thing as that "make it your self" intake system you can buy at pep biys where you buy each peice seperatly
-drew
-drew
#65
It IS a cold air intake, and yes it is overpriced. I would say it is a higher quality piece than a do it yourself. It fits like it should and dosen't rub anywhere like I here some of the other kits do, so maybe you get what you pay for.
Dennis
Dennis
#67
It's a cold air intake. The box is sealed by the hood when it is closed. Air comes in from the fenderwell fust like yours. If the intake being mounted under the hood makes it wai, yours is too since it has to go through the engine compartment to get to the throttle body.
Dennis
Dennis
#69
Originally Posted by Ron From Jersey
Correct me if I'm wrong. This is 300 bucks for an air filter and a plastic box ?
It's my opinion that the open top and seal aren't designed to seal to the under side of the stock hood, but to a duct mounted to the bottom of the hood that ducts air from a scoop to the airbox inlet. This has been typical GM practice for cold air induction since the '60's. I wouldn't be surprised if there isn't a matching hood in the works.
I ordered one of these yesterday and I will be fabricating my own duct to bring in air from a center mounted scoop to the top of the air box. That ends the CAI controversy - it would then definitely be a CAI system. The stock inlet would then be a "back-up." The so-called Ram Air on the Grand Am a couple years ago was similar, except the duct was fixed to the top of the engine instead of to the hood.
Note that we were told that these are temporarily out of stock, but that a new batch is expected within 1-2 weeks. There was also some indication that these will not be produced after a couple of months, so they may be a moot point soon. Hopefully I will get one before GM cancels them. GM has a long history of this with their performance parts - very low production, no anouncement of availability or cataloging of items. If you are "in" with GMPP, you know. If not, they're here and gone before you know about it.
#72
This intakes cost is $227.54, MY cost as a GM parts department employee is 10% over the dealers cost and that puts it at $250.25 + tax. I can't imagine you finding it much cheaper then this. But if you can let us in on where your getting it from!
#74
http://www.gmpartsdirect.com/results...umber=17800653
DESCRIPTION: Air intake
Performance Air Intake Kit
This kit is NOT for SS and SS supercharged Cobalts.
thats what it says on the site. i was really considering this intake too. do they have one specifically for the SS 2.4?
#75
If it throws codes, I will NOT be a happy camper!
If the intake and my scoop (both in transit) come in before the weekend, I will be busy butchering a perfectly good SS hood and installing a part that is specifically prohibited for my car Maybe I'll try just the intake first BEFORE cutting the hole!
