GMPP Intake Manifold
Old 03-24-2009 | 03:31 AM
HunterKiller89's Avatar
Originally Posted by Dunkinuts
but again isn't the inlet for the manifold on the wrong side for the 2.4?
you're not gonna find an intake manifold that will bolt up to the stock intake location for a 2.2 or 2.4. A custom intake is required no matter which manifold you chose
Old 03-24-2009 | 07:47 PM
celicacobalt's Avatar
I need an intake manifold with the intake in the middle and i would be good to go.
Old 03-24-2009 | 07:57 PM
Jn2's Avatar
Jn2
conctact vulcan if your serious im sure he can make that happend for you
Old 03-24-2009 | 11:20 PM
Dunkinuts's Avatar
Originally Posted by Zdeuce4
why are u so against the vulcan mani??
I am not, I just want my inlet for my intake manifold on the passenger side of the car... is that to much to ask for? I wouldn't think a stock replacement would be that hard either.
Old 03-24-2009 | 11:36 PM
Jn2's Avatar
Jn2
He can put it on that side if you want...request it, he's done one with the flange on that end. I think it went on a custom rwd project car.
Old 03-24-2009 | 11:41 PM
Dunkinuts's Avatar
hmmmmmm I will have to email him.
Old 03-24-2009 | 11:43 PM
ColeJJones's Avatar
Bannned
someone fill me in what velocity stacks are
Old 03-24-2009 | 11:45 PM
Karo's Avatar
Shoot me a PM / e-mail if you would like the Race Proven 1500 HP GM Racing unit, we can get you a great deal on one.
-Karo
Old 03-24-2009 | 11:46 PM
Jn2's Avatar
Jn2
Wikipedia it :p they help draw sorrounding air in, for better flow vs a regular opening
Old 03-24-2009 | 11:47 PM
Dunkinuts's Avatar
Wikipedia is your friend.....
The term "velocity stack" refers to an IR (individual runner) intake arrangement, where each cylinder has it's own inlet port. A velocity stack may be used with or without an "airbox" or plenum and the length and shape of the device determines several items, including.
1. Average dynamic air flow rates into the engine under the chaotic intake airflow and pressure conditions of a running engine.
2. Pressure wave propagation and recovery rates as a factor of the inlet radius and inlet side profile.
3. Average dynamic air velocity across the inner diameter.
Used with or without an "airbox". They are designed to:
1. Allow smooth and even entry of air into the intake duct with the flow stream's boundary layer adhering to the pipe walls.
2. Allow choosing of the effective rpm range of dynamic compression (cylinder fill rate).
3. Allow choosing of the overall dynamic compression by choosing inlet profile.
Old 03-24-2009 | 11:49 PM
  #36
ColeJJones's Avatar
Bannned
thanks. good info to post right there
Old 03-24-2009 | 11:54 PM
  #37
elecblue06's Avatar
j00 need saab intake manifold
Old 03-24-2009 | 11:59 PM
  #38
Jn2's Avatar
Jn2
Be Vulcan is the only one to offer a customisable manifold
Pic :
-your flange(l61, le5, lsj, ls1)
-pic your flange position/angle
-pic your color
-pic your runner size and lenght
-pic wether u want velocity stacks or not
The saab is only good for so much pwr, 300+ it's a restriction, y u think that 370hp cavy wanted my Vulcan one, the saab wasn't flowing what he needed
Old 03-25-2009 | 12:03 AM
  #39
elecblue06's Avatar
Pic :
-pic your color
what about if you ported it ?... FAWRKX looks like i'mg etting the vulcan one again lol
Old 03-25-2009 | 12:09 AM
  #40
Jn2's Avatar
Jn2
porting will help but u would need to cut it in halve, port it all over, and weld it back..might aswell buy a Vulcan one after all that
Old 03-25-2009 | 12:19 AM
  #41
elecblue06's Avatar
true.. DAMMIT.. i thought i cut 400 out of my build cost over here but NOOOOOOO
Old 03-25-2009 | 12:20 AM
  #42
I will have to look into vulcan then. thanks.
Old 03-25-2009 | 12:27 AM
  #43
vulcanturbo's Avatar
Thanks guys JN2 is right, if you ask, we can customize these manifolds to any required specs normally with no extra cost!
Old 03-25-2009 | 12:29 AM
  #44
malckom's Avatar
Hey bro I have that part on my 07 cobalt ss/sc with the gmpp touring exhaust and I love it. I also have the gm proforamce catolog and that part will fit on your car but like me if you get that go for one of there exhaust they are great my isn't to load but has a throaty purr. Also I here are the part numbers for the exhaust.
17802111 performance
17802110 touring
Write back when you make up your mind
Old 03-25-2009 | 02:02 AM
  #45
Jn2's Avatar
Jn2
Gmpp exhaust is to small, 2.25"id, weak sauce..atleast a full2.5" for a lsj, 3" if your 250+whp
Old 03-25-2009 | 04:45 PM
  #46
Dunkinuts's Avatar
awesome, so you can get the LE5 flange with a very close to stock inlet for the manifold?
DarrenGC
12-24-2021 01:55 PM
01-12-2016 12:01 AM
no_ss
10-18-2015 11:58 PM
patooyee
10-15-2015 05:11 PM
10-13-2015 09:32 PM
Quick Reply: GMPP Intake Manifold
