Got my TRIFECTA TUNE!!
Old 02-12-2009 | 10:08 AM
Zdeuce4's Avatar
fastest NA 2.4? yes lol..
Old 02-12-2009 | 10:53 AM
Dunkinuts's Avatar
nice, but the real question is spraying taking the car out of the NA category?
Old 02-12-2009 | 02:52 PM
_UnLiMiTeD_'s Avatar
most consider it to take it out of the NA category. Its basically adding a temporary supercharger to the car
Old 02-12-2009 | 03:15 PM
mmcgee123's Avatar
when i refill my bottle and get the dragradials on it i will
Old 02-12-2009 | 05:43 PM
ClearImageAuto Dan's Avatar
Nitrous Oxide 101
Nitrous oxide is consider a "chemical injection". It definitely does NOT allow you to compete in an "NA" class.
Nitrous is made up of (1) one oxygen molecule and (2) two nitrogen molecules. The Nitrogen molecules act as a carrier for the oxygen.
In order to make more power you need to burn more fuel.
In order to burn more fuel you need more oxidizer (oxygen).
Nitrogen will NOT burn so the result from using nitrous oxide is a tremendous increase in exhaust gases since you have burned more fuel and oxygen AND you have all that nitrogen left over.
That being said, if you choose to use nitrous oxide, especially on a supercharged engine, you will greatly benefit from a free flowing exhaust system; header, converter and cat-back. When on "the bottle", you will want the largest primary tubes and exhaust as possible. Off the bottle you may give up some torque but your mileage will increase.
I hope this helps.
Supercharged06SS
12-11-2022 04:47 PM
05-28-2022 03:47 AM
no_ss
10-18-2015 11:58 PM
10-13-2015 09:32 PM
anotherslowlnf
09-29-2015 03:52 PM
Quick Reply: Got my TRIFECTA TUNE!!
