h and r springs havent settled ? ..
ok soo a few weeks ago i installed h and r springs ..within a week the front was significantly lower ..and the back nothing..in fact one side on the back seems high then the other..i have not go an alignment..planning on doing so tmr but im going to go bak under there tmr to see if i can find the problem cuz theres no reason one side should be higher….want to find the problem b4 i get an alignment and have to do it again ..and in turn another alignment ..any1 know what this could be?
Did you get the H&R sports or race springs? Sounds like the race since they gave your car a major rake stance. How much of a difference are you seeing between the two rear wheels? These cars sit with the rear driver side slightly lower than the rear passanger side. But if it's a huge difference than somethings not right.
DANRICKARD
10-01-2015 12:08 AM
