Hahn Racecraft Cobalt SS 2.4 Turbo Prototype!
Old 08-06-2006 | 01:41 AM
  #126
k2kwj's Avatar
awesome. simply awesome this thread should be sticky...
Old 08-06-2006 | 09:21 AM
  #127
mike25's Avatar
Originally Posted by PpAzZ1101
I'm not sure what you mean by fuel productive. I was taught that in cars with a MAF sensor, the sensor is usually placed before the turbo (in the intake piping) and a bypass valve is used to vent the pressure from the charge pipe back into the intake piping (after the MAF sensor). Hahn's setup places the MAF sensor in the ic-tb pipe and vents the pressure before the ic into the atmosphere with a blowoff valve (therefore venting before passing the MAF sensor). I think the advantage of this would be more accurate readings from the MAF sensor and probably better overall performance of the fuel management system.
yea thats what i was gettin at....as far as the fuel productive part its kinda hard to explain what i had in mind...what i was gettin at was that by placing the maf sensor in the ic-tb piping the air would be cleaner and colder and there for there would be less probs. with lean codes and what not....maybe it wouldnt be more fuel productive but it would be healthier for the engine.....
Old 08-06-2006 | 09:35 AM
  #128
mike25's Avatar
Bill i have a some questions for you also:
1. if we were to installt his kit ourselves ( i will most likely do this becuase i think it would be fun and no one where im at will do it) , how hard of an installation am i looking at...others have said it shouldnt be too hard....and im wondering how hard you think it would be...
2. if you could could you get us a round-about price of what this kit will cost?.....most of us speculate around $4000....is that correct or no?
3. for your oil supply and return lines to the turbo...did you have to make any special taps or were there already allowances made in the oil pan for these lines ( i think some1 posted up a pic of a pre driled hole sealed of for tapping)....how hard was that to do?
4. i dont know if this would work but couldnt the intake be re run to the front left fender?....although that would require new piping and further delay production...
5. is that fuel rail your using the stock fuel rail or a new one....it doesnt look stock to me...?
6. and last what is your reason for puttin the MAF in the ic-tb piping...i personally think it is good idea becuase of cleaner and cooler air but i am curious what you have to say about that?
overall the pics look great and i cant wait to get the turbo kit....keep up the good work and i look forward to some answers...thanks
Old 08-06-2006 | 09:51 AM
  #129
BlkSS4dr's Avatar
Oooooooo I want it NOW...I can't wait
Old 08-06-2006 | 12:46 PM
  #130
darklordxenocide's Avatar
Originally Posted by Ljavy17
WOW I bet that car sounds SICK> can u guys take a sound recording.
As Bill is extremely busy, and if he can't get around to it... i would happily take a sound clip for all of you when i get it back later this week! Plus more pics with 3" exhaust and powdered pipes!
Old 08-07-2006 | 12:15 AM
  #131
Halfcent's Avatar
I'm old school
I can answer that one for you. The L61 block has a cast in dimple in the lower crankcase that was originally intended as an oil return location. It was a left over design from the Saab engine. Here is what it looks like:
The problem is, with the engine installed in the car, it is damn near impossible to get a drill up there, and then to tap the threads. Also, if you have an automatic trans, even if you did have that hole tapped, the trans blocks any ability to run a line there.
SO... Instead you drill and tap the oil pan directly above the pan drain bolt, which just so happens to be directly below that dimple on an assembled engine.
Remember, this an L61 engine. I don't know if the LE5 has that dimple, but I'm betting you still tap the oil pan in the exact same spot.
Old 08-07-2006 | 09:46 AM
  #132
Hahn RaceCraft's Avatar
Originally Posted by Dragonsfire12345
So... ummm what do you gotta do to make a kit for the 2.4 with the auto tranny?
We'll need to prototype on an auto trans model to determine physical differences (an obvious one being the turbo-to-intercooler piping), as well as perform engine and transmission calibrations.
Old 08-07-2006 | 09:51 AM
  #133
Originally Posted by Brandon97Z
So will the kits have the 20g we see here or the 16g like the solstice kits?
This has yet to be determined, but we are leaning towards doing the 20G as the standard offering for this system. There's a number of reasons for this, mostly based on the FWD vs RWD configuration, as well as market demographic differences.
Old 08-07-2006 | 10:01 AM
  #134
cvenom2122's Avatar
Thumbs up
this company looks promising! im looking forward to the twincharged kit as long as it fits on my 04 redline
Old 08-07-2006 | 10:08 AM
  #135
PpAzZ1101's Avatar
Promising? Haha.. Hahn's already well-established in the world of turbocharging. Especially when it comes to Ecotecs.
  #136
Mike, here's some answers:
1. Most of our systems are designed to be installed by either skilled enthusiasts or pro mechanics. We exhaustively document and detail the systems, with the best instructions and tech support in the industry. As it's effectively impossible for me to do anything more to evaluate your personal skills, suffice to say...if you have a pro auto mechanic friend looking over your shoulder to keep you out of trouble, then doing your own installation should be fine.
2. You're in the ballpark!
3. This system features a new approach we have developed for oil feed and return that is the easiset yet. No oil pan removal, no drilling onto the engine itself!
4. Frankly, at the power level of a Stage II, the current air filter location is no problem. The humongous intercooler is amazingly effective at these power levels. Re-configuration of the air inlet is just unneccesary expense at this juncture. For higher power levels, we'll be looking at airbox or other cold air inlet possibilities.
5. Yep, that's a stock fuel rail. These new sheetmetal fuel rails are awesome!
6. We've found that this is where the MAF works best based upon rather exhaustive development.
Thanks for your interest!
Bill i have some questions for you also:
1. if we were to install this kit ourselves (i will most likely do this because i think it would be fun and no one where im at will do it) , how hard of an installation am i looking at...others have said it shouldnt be too hard....and im wondering how hard you think it would be...
Old 08-07-2006 | 12:40 PM
  #137
victory_red_SS's Avatar
LSX RWD S/C conversion
Hello Bill Hahn
Not to jack this thread but could you please take a few moments and give your expert opinion on twincharging the LSJ, either in this thread or this other thread.
https://www.cobaltss.net/forums/show...d=1#post425199
This would would be very helpful and insightful for those of us going this route as well as all the nay sayers.
Thanks,
Rod
Old 08-07-2006 | 12:49 PM
  #138
Halfcent's Avatar
I'm old school
Really? Interesting. I already put my -8AN fitting in my oil pan when I did my engine build. So I guess I'm covered either way.
Old 08-08-2006 | 09:39 PM
  #139
mike25's Avatar
ok thanks for the answers...that was really helpful....and to the part about installing do the instructions come with pictures or just really detailed instructions...?
Old 08-09-2006 | 10:42 AM
  #140
You are welcome! Detailed instructions are included, with a lot of useful information, step-by-step procedures, and photos too.
Old 08-09-2006 | 11:02 AM
  #141
mike25's Avatar
ok great that makes it 10 times easier...once again thanks for the help
Old 08-09-2006 | 12:19 PM
  #142
YoAdrian's Avatar
Man, I hope 4k is not the ballpark number for Stage 1. I was hoping it would be around $2,500. 4k is pretty steep.
Old 08-09-2006 | 12:32 PM
  #143
No sir, that's definitely Stage II. And its strictly a ballpark approximation for now!
Old 08-09-2006 | 12:33 PM
  #144
YoAdrian's Avatar
Great!
Old 08-10-2006 | 12:37 AM
  #145
Wo|F's Avatar
could we have a final detailed list of everything that comes with the kit? please?
Old 08-10-2006 | 01:03 AM
  #146
r0me ag3nt's Avatar
I have not opened this thread since the pics were on....and i know this is a repete I WANT ONE!
Old 08-10-2006 | 10:10 AM
  #147
We're not quite able to provide a final list at this time, as development is not yet complete. However, I can provide a preliminary one to give you a working idea of the kit contents...and this is probably 95% or better correct at this time.
  • Super 20G Turbocharger assembly w/adjustable internal wastegate (easily reconfigured for higher boost levels)
  • Turbo Manifold, TIG-welded
  • Exhaust outlet/02 sensor housing, TIG-welded, cerametallic coated
  • Downpipe with or without high-flow catalytic converter, mandrel-bent, TIG-welded
  • Front mount intercooler, 24x6x4.5 (648 cubic-inch core volume), TIG-welded sheetmetal
  • Air intake system: K&N filter, mandrel-bent piping, TIG-welded, powder coated
  • Air charge piping: mandrel-bent, TIG-welded, powder coated
  • Blow-off valve
  • Fuel system modifications including larger injectors and PCM reprogramming
  • Quality silicone hose couplings
  • Quality non-cutting hose clamps
  • Braided stainless steel and hi-temp silicone turbo oil feed and return systems
  • Complete hardware kit
  • All needed gaskets
  • Detailed instructions
  • Overall HP capability of system components: 475+ HP (when used with internally enhanced engine and attendant fuel system mods)
  • Expert technical support via telephone or email every weekday from the leading Ecotec turbocharging company (more Ecotec turbosystems delivered than all others combined)
  • One-year, unlimited mileage warranty on all components except manifold, which carries a five-year, unlimited mileage warranty against cracking
  • Design, calibration, and manufacturing performed and/or overseen by Bill Hahn Jr, who personally boasts 30 years of turbocharging experience
Old 08-10-2006 | 03:41 PM
  #148
Ok guys, i should have the video here on Saturday, (pending weather conditions) so be ready to see what she sounds like with a 3" exhaust, and what she looks like with custom powder coated pipes!!!!
Old 08-11-2006 | 01:32 PM
  #149
celicacobalt's Avatar
  • Blow-off valve
this sounds great and i cant wait to utilize these components on my car, i heard you finally have an automatic 2.4 test car that you will be using in the next few months, is that true
Old 08-11-2006 | 02:40 PM
  #150
We're still looking for one in the Chicago/Great Lakes region, so if you know of a qualified candidate, please send them our way!
Quick Reply: Hahn Racecraft Cobalt SS 2.4 Turbo Prototype!
