header
Old 04-04-2012 | 06:41 AM
jerseyg5gt's Avatar
header
2.4 07 g5 gt automatic
I got my supercharger kit. Im waiting to put it on till I get more parts.
After a lil research it looks like badmab or zzp header are on the tops of lists.
My question is which is the better install and quality. I kno some headers are made better and the install is smoother. I just did headers in a new camaro ss and it was a breeze ! Which prompted my post.
And which d/p. I didn't research them much.
Don't forget I'm going supercharged so whatever size you recommend for that.
Old 04-04-2012 | 06:45 AM
donald's Avatar
get the badmap header and zzp 2.5 dp thats what i am getting i am na no boost but for new for both are like 329.00 for you you want 1.75 primariessince your supercharged and the rest 2.5 piping will be enough
Old 04-04-2012 | 06:47 AM
jerseyg5gt's Avatar
That all sounds well and good. Just waiting for opinions to follow.
Old 04-04-2012 | 06:52 AM
donald's Avatar
sorry can't spell bad-mab
Old 04-04-2012 | 06:54 AM
jerseyg5gt's Avatar
It didn't even register but I knew what u meant
Old 04-04-2012 | 08:38 AM
jerseyg5gt's Avatar
I'm definitely going with dual slp loudmouth II mufflers also
Old 04-04-2012 | 09:09 AM
manny45's Avatar
I went 3in all the way through. ZZP longtube headers and zzp downpipe. I say ZZP > bad-mab cause bad - mab is a shorty header which focuses on low end and if u are modding a sc u will have enough low end and u can focus better on mid or higher rpms. I would of prefered mid length header....but i went Longtube as it worked on the higher end which are cars fall flat on the higher rpms and this helps alot... that is what i think and its just my opinion.
Old 04-04-2012 | 09:11 AM
jerseyg5gt's Avatar
I like the way that sounds. How was installation of the long tube and d/p?
Old 04-04-2012 | 10:22 AM
manny45's Avatar
Well wasnt hard they bolt right up I went 3in and i like it the only thing is the car is too loud...
Old 04-04-2012 | 11:02 AM
noorj's Avatar
I like my set-up but I also had the re-surface my header flange, which if I didn't have access to a mill would have been a bitch. So I'm sure ZZP's quality would be better, better fit+finish but that is excepted with the higher price. Whatever you decide get 3 inch, being SC you will benefit from this.
Old 04-04-2012 | 11:04 AM
bluebalt07's Avatar
I agree get the long tube header combo. I love mine except I also agree it is quite loud but not a ricey loud so I tolerate it. The long tubes are designed to optimize a supercharged setup and I think they do that job well. Plus they are 304 stainless so they will never rust and never need replaced. Install is easy after you figure out how to maneuver the header down through the tiny space between the engine and firewall, just takes so twisting and patience.
Old 04-04-2012 | 12:22 PM
donald's Avatar
just my opinion and it has been stated here in different threads that sc dosen't need 3 inch unless you have like a tvs or mp90. so its not gonna do anything but make it louder
Old 04-04-2012 | 12:58 PM
manny45's Avatar
actually u are wrong on that... The header and DP u do benefit from it being 3in. the exhaust is what you wont need to change... cause its already 2.5 all the ss/sc that i know have gone to a 3in dp...
Old 04-04-2012 | 01:34 PM
hhrfreek's Avatar
Either way if you do a full exhaust 2.5 or 3" its gonna be loud and resonate in the cabin. Do 2.5 or 3" cat back with a chambered muffler, which I think ZZP now sells. You are going to hate yourself(and so is your girlfriend) if you do a straight through muffler. I have the ZZP 2.5 cat back(magnaflow muffler) with badmab and 3" catless ZZP downpipe and it was loud as hell. I had a 2.5" adapter welded on to the stock muffler last week and is way better with little resonating.
Old 04-04-2012 | 02:00 PM
donald's Avatar
sorry i meant cat back cause im na no booost but doing a 3 inch dp and 2.5 cat back
Old 04-04-2012 | 02:02 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
zzp long tubes! no cat!
Old 04-12-2012 | 08:24 PM
CordiaDOHC's Avatar
I'm running a zzp shorty header,cti 3" to 2.5" catted downpipe and the slp loudmouth catback. And let me tell you its ungodly loud and raspy above 3k rpms. It runs very nicely and pulls nicely as well though. But id suggest zzps catback as well if your going Sc. From what ive heard its supposedo be one of the quieter ones out there.
Old 04-12-2012 | 10:23 PM
noorj's Avatar
You don't need 3 inch being NA. You will only loose torque and not gain any power with a 3 inch downpipe.
Old 04-12-2012 | 10:27 PM
n0xid's Avatar
Pfft, go with the vortex!
Old 04-12-2012 | 10:53 PM
bluebalt07's Avatar
Dyno proven to take away power compared to stock
Old 04-13-2012 | 01:02 AM
n0xid's Avatar
Who cares it's ******* badass haha
goaliemo
09-28-2015 01:37 PM
z28addiction
09-28-2015 12:03 AM
09-26-2015 06:44 PM
budah93
09-15-2015 07:23 AM
hacadacalopolis
09-08-2015 11:42 PM
Quick Reply: header
