Help!!! trouble
Old 08-28-2008 | 10:29 PM
glen229's Avatar
Help!!! trouble
so i installed my header... went smoothly no issues... i start it up and its pissing antifreeze from under the car................. why could this be happening
any help would be greatly appreciated
Old 08-28-2008 | 10:30 PM
Super_SS's Avatar
wtf?
Old 08-28-2008 | 10:51 PM
Dead Zen's Avatar
there is the coolant line in the back of the motor under the header. did you do something to it?
see where the words are? thats the collant line im talking about
Old 08-28-2008 | 11:01 PM
glen229's Avatar
thank you for that pic... its so late i gave up my dad and i are going to look in the morning ill let you know... i appreciate the help man!!
any other suggestions it is leaking from under the header so it could be that
is there any way i could have cracked the head?? i doubt it but id be fucked if i did idk why coolant would be running out
Old 08-28-2008 | 11:03 PM
Dead Zen's Avatar
i dont really see how you could have messed up the coolant line. but its a start to look at man
Old 08-28-2008 | 11:04 PM
glen229's Avatar
i appreciate the help im new with cobalts so i dont know every nook and cranny in the car like my older ones.......thanks
Old 08-28-2008 | 11:05 PM
CobaltSS 16's Avatar
Just lift the car up and check where the coolant is leaking from, and go from there.
Old 08-28-2008 | 11:07 PM
glen229's Avatar
its harder than it sounds theres a shield on the bottom of the header that has one bolt thats very hard to get out because of the shifter linkage....... the header is like stuck on so when i get it off it will be clear if i gouged a hole in that coolant line... the new header is very close to it so idk
Old 08-29-2008 | 11:20 AM
Viper33884's Avatar
I had the same problem with my CA header, I just popped out the little tab, gave the coolant line a little twist so it would clear the header and put some high temp silicone around the back side of the coolant line and good to go.
Old 08-29-2008 | 11:22 AM
njg5gt's Avatar
that shield is a bitch to get off, but once you get it off it will make diagnosing this problem much easier. i just bent those two cables carefully out of the way to take out that 10mm bolt
Old 08-29-2008 | 11:27 AM
D4u2s0t's Avatar
i doubt it. what did you torque the nuts to? they should be to about 10 ft/lbs which is not that tight. My guess is like others said you hit the pipe running from the water pump and knocked something loose.
Old 08-29-2008 | 11:36 AM
Viper33884's Avatar
He didn't knock anything loose, the header puts pressure on the pipe and opens the seal a little bit causing it to leak.
Old 08-29-2008 | 01:31 PM
LS6Rally's Avatar
hey glenn let me know if you cant figure this out. i can prolly take a ride up to you place this weekend if you cant figure it out. ill take a look
Old 08-29-2008 | 03:04 PM
glen229's Avatar
thanks guys im going to look at it tonight ill let you all know ls6 i appreciate it!
so if i start the car and theres no coolant in the water pump.. is this bad will i wear the bearings out by the time the new coolant from the overflow works its way to it???
Old 08-29-2008 | 03:07 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
No dude its cool. Just keep an eye on your temps and youll be fine. Nothing over 230ish.
mkulrey13's Avatar
oh glen...you make me i was going to ask if your comming over to help us with dana's mani isntall but i guess thats a no
Old 08-29-2008 | 03:43 PM
glen229's Avatar
how can i move that coolant line out of the way just twist it?
Old 08-29-2008 | 03:59 PM
Viper33884's Avatar
Yes, but there's a tab that holds it from twisting, just bend that straight and your good, you will see it.
Old 08-29-2008 | 04:07 PM
glen229's Avatar
Thank You So Much
Old 08-29-2008 | 04:14 PM
Viper33884's Avatar
Yup no problem.
Old 08-29-2008 | 04:51 PM
glen229's Avatar
theres a small noise like a swquikey sound coming from around the belt area maybe water pump.. the car is not over temp .... any ideas what this coould be from.. i didnt install that shield under the header but i dont think thats the issue
Old 08-29-2008 | 04:58 PM
Viper33884's Avatar
Loose belt, like the belt tensioner.
Old 08-29-2008 | 05:00 PM
glen229's Avatar
dude u are the man... does anybody have a how to on this? or a pic of what bolt
Old 08-29-2008 | 05:04 PM
Viper33884's Avatar
Should be some How To's in the LSJ section maybe about how to swap pulleys out. Or take it to a shop and they should tell you what's up and maybe charge you $20 to fix it.
Old 08-29-2008 | 05:07 PM
glen229's Avatar
could it be slipping from the antifreeze
Quick Reply: Help!!! trouble
