HIDs stopped working
Old 12-11-2010 | 04:36 PM
Benzer's Avatar
Okay I just got a set of used DDM tuning HIDs a couple days ago, and today they stopped working. They turned on when I left my house, but when I started it up to go home, they didn't. They came back on for a few minutes while driving, but then turned back off and I haven't been able to get them working since.
My garage is dark so they always came on regardless of how bright it was outside. Plus all the gauge/radio/hvac lights came on so I know it's not the photo sensor. I'm thinking it might be the ballasts because they use to hum but now they don't. I have a harness and I checked the polarity. It might be the relay, but I think its getting power to the ballasts because I hear a loud click whenever I switch from high to low beams, as they did while they were working.
I have my old halogens I can put back in until I can get it resolved. Has anyone been in this fix before? Do you agree that one if not both of the ballasts are bad? Could it be the relay?
Old 12-11-2010 | 06:16 PM
Benzer's Avatar
I did some more research and most sites say they require at least 20 amps. I was using the original fuses, which are 10 amps.
Old 12-11-2010 | 06:26 PM
heathkidder's Avatar
i dont believe i changed my fuse but you may want to take everything back apart and rewire and connect it correctly if still an issue may be the ballasts
Old 12-11-2010 | 06:43 PM
ecot3c inside's Avatar
same thing happened to me. they came on whenever they felt like it, sometimes one, sometimes both, but most of the time neither worked. I said **** it and put my stock bulbs back in, because from what I can see ground was good, power was hooked up, but they just did this randomly (when the cold started) had the same setup for like 6 months.
Old 12-11-2010 | 07:34 PM
kidcrash603's Avatar
it also sounds from your description like you are still using daytime running lights, which is a big no no with HIDs.
Old 12-11-2010 | 10:42 PM
^ i never use my lights during the day pointless and just waste of hids
Old 12-11-2010 | 10:56 PM
Benzer's Avatar
I checked and rechecked the wiring, and it seemed to be alright. I'll try the fuses tomorrow and if they don't work I'll try ddm monday and see if I can buy a couple replacement ballasts. If and when I get them working, I'll never use the driving lights again.
Old 12-11-2010 | 11:07 PM
its a waste to
Old 12-12-2010 | 12:49 PM
Benzer's Avatar
OK I just did some more research about using the driving lights and they say that using them can burn out the ballasts That's probably what happened to me. The weather's been kinda gloomy since I put them in so they would come on and off sporadically throughout the day. That probably did mine in. I think the best thing to do at this point is to get a couple replacement ballasts. Just wish I knew that before I put them in.
Old 12-13-2010 | 01:14 AM
cobalt4doorss's Avatar
i have hids on my car i never changed the fuse they work fine ! but then agen i have after market head lights were did u put the balist? did u get water in them
Old 12-13-2010 | 01:19 AM
Ting-ting's Avatar
mine keep blowing my fuse
Old 12-13-2010 | 09:41 AM
RickyBobby's Avatar
AHH! DDM FTL......They are hella bad
Old 12-13-2010 | 11:22 AM
Nacademus's Avatar
No they're not-support your statement. Here comes the pissing contest.
Old 12-13-2010 | 12:24 PM
Everybody has opinions!
If every kit they sold sucked, they wouldn't still be in business!
Nac, we've gone back and forth before, this isn't about that. You making that post IMO is what would start said "pissing contest" lol.
Hope the OP gets it worked out.
Old 12-13-2010 | 03:22 PM
Benzer's Avatar
I put them where they suggested, under the headlight bracket. It didn't rain since I put them in, so they didn't get wet. I'm calling DDM today to see if they can hook me up with a new relay. It seems kinda flukey that both ballasts would blow at the exact same time.
Old 12-14-2010 | 10:58 PM
CordiaDOHC's Avatar
my ddms are still going strong. No fuse upgrade no wiring harness
twin 6k hid's one for the driving lights and one for the low beams.
Though I do plan on upgrading to a higher quality setup (probably prolumen or phillips) But I will pass the ddms down to a friend.
bigdeertz
11-17-2016 09:41 AM
biniecki
10-25-2015 02:23 PM
dennis69
10-20-2015 04:49 PM
SSLOW06
10-01-2015 07:21 PM
Quick Reply: HIDs stopped working
